1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming, streaming games on Twitch.tv, college work (word processing and basic programming mostly), media
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I want to keep it below $1100.
3. What country YOU will be buying YOUR parts from.
US
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
N/A
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I'm not a fanboy, but I think that Intel is overall better for me due to streaming.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I have no existing parts to use.
7. IF YOU plan on overclocking or run the system at default speeds.
I want to overclock the graphics card, and I want to be able to OC the CPU just in case I need a little boost for streaming a certain game.
8. What resolution, not monitor size, will you be using?
Aiming for 1920x1080 or better
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
I'll need to order everything by the end of next month. I know that's a long time, but I need to plot out this build budget-wise so I have a general idea of the overall cost and if I need to save more.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Yes, I need Windows.
Here's what I have right now: http://pcpartpicker.com/p/1DSQH
Mainly, I'm concerned with the case, the monitor, the power supply, and the motherboard right now. If you feel the need to make a case for changing anything else right now, go ahead. Suggestions on thermal paste and case fans are appreciated as well.
US
N/A
