Can't recall any unlocked Xeons?
You can probably get all the cores to run at the turbo multiplier though.
E5 16xx have definitely been 100% unlocked for all 3 generations so far. Now whether that's still the case with v4 idk.
I've seen reports that Intel has locked down the E5 16xx v4 series.
Very similar to the i7-6850K, in specs and price. Why not get the unlocked i7?
http://ark.intel.com/products/94188/Intel-Core-i7-6850K-Processor-15M-Cache-up-to-3_80-GHz
Yeah, multiplier is locked! I'm sure I could probably raise bclk a bit but imo it's just not worth messing with.
58 are showing the same result like t
Yeah multiplier is definitely locked. Cpu strap looks to be adjustable. I haven't really tried though so i'm not positive.
I'm not hopeful with Broadwell based Xeon as well.
It doesn't seem to be overclockable at all. So I decided not to go for Xeon.
Thanks again for helping me out with all the questions.
No problem. Good call, I definitely wouldn't buy one if overclocking is important to you. My chip will eventually find it's way into a server and i'll be buying a server board for it.
My old system is X5660@4.6GHz and now I am building a new gaming PC, trying to figure out what the best option is.
Well I'm still thinking about Xeon 1660 V4 though. 6800K might perform better for gaming so I can't really decide yet lol
