if you are a KT-424 user,
tell me how loud it is..
umm, i am guessing that the air vent infront will make some noise
Originally posted by: EternusNox
I just bought a KT-424. For the price you really can't beat it. The 80mm fans won't be any louder than your other system fans. It does have a control knob underneath the front panel if you want to turn them down. Kinda wish the knob was on the outside but it could be with a simple modification. As far as that goes, taking the front panel off is as easy as just pulling on the bottom of it and then snapping it back into place when your done. I don't have any complaints so far. I paid $88.95 plus shipping from ZZF.
Originally posted by: DaFOBulous1
Lian Li...are nice.
Depends if you want a lil show for ur case.
The Thermaltake cases are really nice....the Tsanami? I just got one...REALLY lovely.![]()
Originally posted by: Zap
Is that "rocking switches" your fan controller you were talking about? If you were spending that much on a case, why not get a more modern fan controller? Here's a cheap black one (made out of aluminum, no less) that lets you do variable 7-12v and is backlit in blue for some bling-bling: SVC $13
I was looking into the Kingwin case... really like it except... wish it used 120mm fans. My current tower cases all use 120mm fans and I like the high airflow/low noise.
Originally posted by: w00t
get a pc-61 with the plain black casing and i will trade u for my window on my pc-65B
Originally posted by: Zepper
You need to chop your pix down to under 30kB each. I use IrfanView takes me about 10 seconds to chop any size pic down to size for using on the web. Have pity on those of us still using dial-up...
.bh.
