Amdhal law is not at play in CB R15, the test is supposed to scale at almost 100% even with 64 cores.
But it does not. From anandtech.com/bench
Code:
Ivy Bridge
E5 2697 v2 24c/48t 3.0 GHz turbo - 2988 - 41.5/c/GHz
E5 2687 v2 16c/32t 3.6 GHz turbo - 2508 - 43.5/c/GHz
E5 2687 v2 8c/16t 3.6 GHz turbo - 1297 - 45/c/GHz
i7 4960X 6c/12t 3.7 GHz turbo - 1097 - 49.4/c/GHz
Haswell
E5 2697 v3 28c/56t 3.1 GHz turbo - 3994 - 46/c/GHz
E5 2687W v3 20c/40t 3.2 GHz turbo - 3060 - 47/c/GHz
E5 2650L v3 24c/48t 2.1 GHz turbo - 2433 - 48/c/GHz
i7 5960X 8c/16t 3.3 GHz turbo - 1337 - 50/c/GHz
As the the core count increases, the score/core/GHz decreases. Take the E5 2697 v2 24c/48t for example. If scores scaled linearly with cores, then it should score 49.4*24*3=3556. On a quad processor system, the scaling should be even worse since code and data are local to one processor only (unless you're implying that Cinebench is NUMA aware).
Anandtech says Cinema 4D is NUMA aware. I guess core scaling would be significantly worse if it wasn't.
