It's possible the service won't allow more than one machine. There are plenty of features in network gear to do this.
Your first pictures shows your IPv4 as 192.168.5.217, and your gateway as 192.168.7.254, and your DHCP server as 192.168.3.254.
That strikes me as wierd, that they would be on different subnets. At least it's pretty weird for SOHO gear to be handing out.
Is it possible, that there are other people in the building doing just the same thing as you, connecting a router via a LAN port, and possibly they are not shutting off DHCP, etc., such that you are connecting to their router, and not the building's router?
Where should I start?
By finding out what exactly is coming out of the wall connection.
If I can see correctly your OP shows an IP of 169.xxx.xxx.xxx which is a none functional IP assigned by default when the computer can not find a DHCP server.
The Router that provides the IPs to the wall outlets can have different configurations.
It can set to provide only one IP per outlet, the IP can be attached to MAC address, or do something else to prevent further Routing etc.
You have to ask. If you know that you are Not allow to use more than one computer and you are afraid to ask, then there is nothing much that we can do for you.
Got it working!
Called in and he told me to plug the "internet" cable into the WAN on the router then enable Dynamic IP in the router and then plug my desktop into the router. Works perfectly!
Thanks guys!
Grats. However now your double NATTED so expect potentially poor performance from certain site / apps. Also typically VPNs and the like will fail hard.
