BF2: Resolution & Hardware Survey!
1024x768 (thinking about customizing to a higher res)
high qual everything
2x aa
cpu oc'd 2.7ghz
99fps more times than not
My full comp description in the link below.
AthlonXP 2500 Barton at 2.2GHz(3200)
BFG 6600GTOC
1 GB RAM at 400MHz
Audigy 2 ZS
Samsung SyncMaster 172x 17in LCD (1280x1024, 60Hz)
Sennheiser heaphones
BF2 set to 1024x768, 60Hz (its stuck there), all vid options medium, distance 100%, 4x AA, sound -> hardware, no EAX filters nor CMSS3D (usually)
The vast majority of glitchyness for me is server side. The game looks fine, but there's some pop-up I'd rather not have. When I unstick the resolution, I might see a hit.
At what resolution are you playing BF2? 1280x960
What level of eye candy (Low, Medium, High)? High
What level of FSAA? 4
What videocard do you use? 6800GT
What CPU? San Diego 4000+
How much RAM do you have? 2GB
Plays nice
1280x960
All high
4x aa
smooth as silk (although the load times are horrible, and lots of choppiness due to page filing) Getting to servers is one thing, horrible again, returned BF2 and got other games out of it 😛
3100+ sempron 2.069ghz
x850xt agp
What level of FSAA?
What CPU?
Are you pleased with how smooth your game play is?
If not, what needs to be improved? (Hardware upgrade, game patch, new drivers?)
1680x1050
High
None
6800GT
P4 3.4E (Prescott)
2GB RAM
Most of the time, the game is very smooth when I'm playing SP. Its hard to gauge MP frame rate because the game is so laggy online.
Pentium 3 Tualatin S @ 1.4GHz 512k full speed cache (vs Half Speed)
512MB Single Stick of Crucial PC133 RAM @ 133MHZ CL 2-2-2-5
ATI 9700PRO 256BIT 128MB DDR
1152 x 864 Game Play Ranges Between 28- 92 FPS Fraps
At what resolution are you playing BF2? 1024x768
What level of FSAA? 4x
What videocard do you use? See below
What CPU? See below
How much RAM do you have? See below
Are you pleased with how smooth your game play is? Yes
At what resolution are you playing BF2? 1280x1024
What videocard do you use? evga 6800gt
What CPU? AMD64 3000+ 2.6ghz
How much RAM do you have? 2x512 BH5
At what resolution are you playing BF2? 1024*768
What level of eye candy (Low, Medium, High)? Almost all medium, 1 low and 2 off.
What level of FSAA? 2x
What videocard do you use? X800 XL
What CPU? A-XP 3200+
How much RAM do you have? 512
Are you pleased with how smooth your game play is? Yes, but I would like to have at least 1gb or RAM to make it smoother.
At what resolution are you playing BF2? 1152 x 864
What level of eye candy (Low, Medium, High)? Medium
What level of FSAA? None
What videocard do you use? 6600GT No O/C
What CPU? s939 3000+ stock speed
How much RAM do you have? 1GB
Are you pleased with how smooth your game play is? Yes & No, want higher IQ
Tweaks R Us 78.05 driver is a must for BF2. Waiting for a nvidia 7 series chip to reach $300 Canadian. EA does have another patch in the works. It's called BF2 Special Forces.
At what resolution are you playing BF2? 1280X1024
What level of eye candy (Low, Medium, High)? Ultra
What level of FSAA? 4XAA,AF (thru profile)
What videocard do you use? dual 6800GT OC's in SLI
What CPU? A64 3500+
How much RAM do you have? 2GB Corsair XMS XLL
Are you pleased with how smooth your game play is? Generally yes, but wish I could run it at 1600X1200 or higher...
If not, what needs to be improved? (Hardware upgrade, game patch, new drivers?) See above
1024X768
Mix of medium and high
Radeon X300SE
P4 2.8 Ghz
1.5 Gigs
I'm pleased overall, but definitely understand that a video upgrade would help.
The game used to be much slower when I was only running 512Megs of RAM. When I upgraded to 1.5Gb, I noticed that the maps loaded much faster. In many cases I'm still one of the first people spawning in new maps. If you have a decent system, be sure to turn your sound up to medium or high...it adds a lot of cool dialog to the game. I didn't notice this setting until I played for a month or so. It makes the experience more realistic.
1600x1200
Everything on high but shadows (medium) and no AA
AMD64 3500 with 1 gig ram and bfg nvidia 6800 with 256megs of ram (PCI-E)
Plays great, no lag.
Everything on high including AA, also have settings in nvidia profile all the way up. Resolution is at 1280x1024. Rig is in sig
