BF2: Resolution & Hardware Survey!
1680x1050
High - Expect for Dynamic Shadows, thats off
None
X800 XL
1.8Ghz AMD 64
2x512MB
I might upgrade to a 7800GTX right now, I am not that impressed. I don't think it's worthwhile to upgrade over this one game.
Anyone have any proof this game does use more than 1GB Ram?
I haven't played much with the settings.
I set it to 1280x960, all high 4xAA and it seems to run better than BFV.
x800XL
A64 Venice @2.4GHz
1GB @ 200 MHz 2-2-2
At what resolution are you playing BF2? 1600x1200
What level of eye candy (Low, Medium, High)? all high.
What level of FSAA? 4x
What videocard do you use? x800 pro
What CPU? AMD64 3700+
How much RAM do you have? 2Gig
Are you pleased with how smooth your game play is? yes
If not, what needs to be improved? still a few bugs and server browser doesn't always work.
At what resolution are you playing BF2? 1280x960
What level of eye candy (Low, Medium, High)? High
What level of FSAA? 0
What videocard do you use? X800 Pro
What CPU? San Diego 4000+
How much RAM do you have? 1GB
no slowdowns
A64 3200+ Winnie @ 2Ghz (Stock)
1024MB Corsair ValueSelect RAM
ASUS N6600GT PCIe 128MB
I run at 1024x768 (my monitor displays weird vertical "off-and-on" lines on 1280x960), with Medium detail on everything and 4xAA. Dynamic shadows on (I think).
Full draw distance (which according to me is still too near).
Runs fine. Will up all settings to High and, if necessary, turn down until smooth.
At what resolution are you playing BF2? 1280x1024
What level of eye candy (Low, Medium, High)? Everything high except textures (medium, runs awful at high no matter what)
What videocard do you use? 6600GT
What CPU? Winchester 3000+ @ 2.5GHz
Are you pleased with how smooth your game play is? I guess, but it randomly stutters for no reason (i.e. if I'm driving with no one near me)
If not, what needs to be improved? (Hardware upgrade, game patch, new drivers?) Looks like the 6600GT can handle BF2 pretty easily, at least with the included drivers (77.30). I think the game mainly needs to be patched.
On the old rig (the new is in the mail, whoopeee 😀 *see sig*)
1024x768@85Hz
Medium to high
9800 Pro
2XAA
1GB ram
Runs like a charm for me. Both single and multiplayer.
//MrFlashy
I play at 1680x1050.
All high settings except textures at medium. It runs fine on high, it just take a round to load the entire map into memory, which introduces very inopportune loading and stuttering while I'm fighting. After a round, it runs great. On medium, everything is able to load from the get-go, and I have absolutely no issues with stuttering when I first start up the game now. I cannot tell a difference in texture quality while fighting, so I leave it at medium.
Playing with a 6800GT on an A64 3200+.
Driver settings are forcing 8xAF.
Software settings are set to 2xAA.
1GB of PC3200.
Runs great with 99% hitch-free action. Only 1% trouble comes from missles and explosions near my position, when it blurs the screen and messes with the sound. The frame rate does chug momentarily while this is going on, but is quickly over. I haven't done an official test, but my guess would be around 45fps 95% of the time.
800x600
Medium/Low
None
ATi 9200 128MB
Athlon Thunderbird 1.4Ghz
Mushkin 512MB PC2100
It runs better than I expected but still pretty bad at 15-25 frames per second.
1920x1200
HIGH everything
No-AA (don't need it at 1920x1200 on a 17" widescreen)
2.0ghz P-M
6800Ultra Go (250mb)
2GB ram
Smooth as silk
What level of FSAA?
What CPU?
800x600
low
none
8500le 128
1800+xp
512pc133
smooth and playable
Home Machine:
1280x1024, High, 16x/6x
3000+ Venice @ 2700
DFI NF4 Ultra-D
512MB Quadro 4400 (X800XL 256MB for backup)
2x512 XMS 3200 (2GB soon)
Work Machine:
1280x1024, Highest, 16x/6x
Dual P4 3.6
Alienware 925
2x6800GT SLI
2x1GB Kingston 3200
What level of eye candy (Low, Medium, High)? All medium, lags in high
What level of FSAA? 0xFSAA
What videocard do you use? 9800 Pro
What CPU? AXP @ 2.0GHz (200x10)
What level of FSAA?
What CPU?
1600x1200 x32
high
4x
6800 GT
2 gigs
A64 3200
At what resolution are you playing BF2? 1024x768
What level of eye candy (Low, Medium, High)? High (though I see this sets Lights to Medium).
What level of FSAA? None
What videocard do you use? 6800GT with the game's 77.30 drivers
What CPU? Athlon XP (mobile) at 2.3 Ghz.
How much RAM do you have? 1 GB
Are you pleased with how smooth your game play is? This seems to be working pretty well. Benchmarking the single player, I'm averaging around 60 fps (36-90 fps).
If not, what needs to be improved? (Hardware upgrade, game patch, new drivers?) I'm sure I could benefit from moving up from an Athlon XP to an Athlon 64, but I don't feel any urgency to do so.
Space
1024X768
All High
No AA
Radeon 9800 Pro
Athlon 64 2800+
1.5GB of Ram
Runs nice and smooth, could enable AA and get near performance levels
I would say there are a few graphical glitches in the game that a patch needs to take care of.
What level of eye candy (Low, Medium, High)? All High
What videocard do you use? Radeon x800xl
What CPU? Athlon64 3000+ venice (stock)
How much RAM do you have? 2x512mb
Are you pleased with how smooth your game play is? yep
If not, what needs to be improved? (Hardware upgrade, game patch, new drivers?) patch to fix all the damn bugs
1280x960
Medium
No AA
5900XT (modded to 5950)
P4 3.0E
1gb of sh!tty ddr400 ram that runs at 320mhz
it feels like its smooth but fraps said otherwise at 24fps in FRAPs now its at about 30fps using the ingame fps and retail game (oh well my new 6800GT should fix that 🙂)
At what resolution are you playing BF2? 800x600
What level of eye candy (Low, Medium, High)?Mix of High/Med with no shadows
What level of FSAA?4x
What videocard do you use?stock 9800pro
What CPU?2.8c stock
How much RAM do you have?1GB OCZ PC-3200
Are you pleased with how smooth your game play is?yes
1024x768
High/Medium (Dynamic Light, Dynamic Shadows, Textures at medium. Everything else high)
2xAA/4xAF
LeadTek 6600GT 128MB
Athlon 64 3500+
1GB Mushkin DDR400
No problems with slowdown, swapping, etc. Game runs smooth.
With my rig in my sig, i cant seem to run any res higher than 1152x864 on BF2. I'm running the drivers that came with the game. I'm trying to hit 1650x1080 res, but somehow the game wont allow me to. any advice?
Make a shortcut of the EXE, then add to the "Targe" this at the end: +menu 1 +fullscreen 1 +szx 1650 +szy 1080
So, the whole thing would look something like: "C:\Program Files\EA GAMES\Battlefield 2\BF2.exe" +menu 1 +fullscreen 1 +szx 1650 +szy 1080
(Note the space before the +medu 1...etc.)
