Better gas mileage?
imported_Condor
5,425
Originally posted by: The Linuxator
Originally posted by: Condor
I had a posting to file serv that I am on. This looks like something to try. This says that adding acetone to gas will result in better performance and better economy. I'm going to try it. Here is the link: link
You sir a DUMBSH!T .
How can you post something that might have placed other lives in danger, or could have caused some members that took your refrences for a fact to end up paying for another car because his got fckd up.... Idiot.
Hey, you kiss your mnother with that same mouth. Chill, just presented the info for comment. Go back to P&N and get back to Bush bashing!
Miramonti
28,653
100
damn, acetone is some strong sh!t...drip it onto your car paint and you'll probably bubble it.
imported_Super
272
Originally posted by: Midlander
Stay away from anything like this. With all the press regarding gas mileage, don't you think the car companies would have demanded gas additives that provide increased mileage? Ditto, BTW, for any gadget you can add to your engine to increase gas mileage. They don't work.
Not exactly. Like i stated earlier and like everyone here prob. knows, you can add/change a lot of stuff in your engine to increase gas mileage. Everything I listed before and crankcase filter, pcv valve, fuel filter, alignments, tire pressure, all-around better air-flow will increase fuel effiency. Of course, nothing is gonna shoot you from 25mpg to 35mpg, but it should get better to the tune of 1-3mpg.
And that one flow master thingy (fan) as seen on tv, does increase fuel efficiency. I don't know how many ppl have come into my work asking for it because they've used it through a company vehicle or a friend has told them about it, but it really does work. However, i think they've been recalled due to some hazard. ha.
Midlander
2,456
Agreed. Keeping your car in tune, maintaining alignment and tire pressure, and all sorts of normal maintenance items will help keep your car up to its original gas mileage. Yes, you can also do some things to the exhaust that might increase mileage to some degree. As for the "take money from the stupid" items, they don't work. But they do make a lot of money for the guys hawking them.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
This thread makes me laugh. Good for Roger though, it iwll keep him in buisness.
S Random
236
gasoline will aswell but not asmuch, put gassoline on one hand then acetone on the other and see what irritates more. As well it can cause leaks in hoses
Kogan
1,331
Lower in the article is says they went from 48mpg to 30mpg by taking the acetone out. That's just unbelievable :) And why would they have to use some scanguage to measure mileage? And why are they measuring gas mileage while the car is moving at 50mph? Recording the number of miles you get each tank should be much easier and more accurate. Seems fishy to me that they've got to all of this work and don't have any real-world tests and results..
If this information is actually useful, we probably would have heard more about it by now (this was posted in march?).
I'll just wait a few more years for consumer hydrogen-electric cars :) $3/gallon isn't that bad anyway.
Greenman
22,395
6,522
Sounds like snake oil to me. The last big secret I heard about was a magnet that you tied to your fuel line, they claimed it aligned the fuel molecules and caused a more complete burn. The common thread in all of the gadgets and additives that get you great fuel economy is that they are suppressed by the evil oil companies.
rhacquer
413
Originally posted by: freeguy007
perhaps try in a neighbor's car first
LOL! or maybe the company CEO, after the next round of RIFs and outsourcing to India or wherever.
The Linuxator
Banned
Jun 13, 2005
3,121
I have a better idea drink some beer overnight and in the morning empty your resvoire in the car's resvoire that ought give you a headstart on the traffic-light downtown ;)
zephyrprime
7,512
Originally posted by: Greg04
Originally posted by: krazzypanda
Originally posted by: blahblah99
Remember, acetone eats plastic/rubber.
And guess what the seals & orings in your engine are made of...
LOL doesnt gasoline eat rubber and plastic too? Hence the movie Collateral Damage where Arnold puts gasoline on the rubberband so that it can break apart causing the grenade to explode.
Why yes, in fact the plastic GAS container I recently filled up at the as station got completely eaten away.
Oh wait, no it wasn't.
This HAS to be the dumbest thread on the forum.
It eats through some plastics and rubbers and not others. The same is true for Acetone.
Lithan
2,919
It works, just not very well.
It damages fuel lines, just not very much.
mikeford
5,671
160
AAA checks all sorts of mileage claims, two things work, a low pressure exhaust system, and a vacuum operated switch that cuts off the AC compressor when the load on the engine goes over some level (latter item now standard in most cars).
Ark
Nobody mentioned that gas tanks on newer cars are plastic!
Sooner or later aceton will make a hole...
Lithan
2,919
Uhh, plastic is a bit simplistic. Aren't they a fancy schmancy near-bulletproof polymer?
radioouman
8,632
That is some reasonable advice for change.
Rubber hoses come in different varieties too. If you use "vacuum line" as a "fuel line" it will deteriorate very quickly. As a mechanical engineer who has a background in plastics, I'm going to have to say that acetone will probably deteriorate the rubber parts more quickly than gasoline, but the effects will not be detrimental because the fuels system parts are already designed to work for years with gasoline running through them.
I wouldn't put acetone on your weatherstripping though ;)
Richardito
1,411
Please, do not be ignorant and try everything that you see. At the Saab 92x forums we already had a discussion over this. Take a look at the rest of the site and you will realize these people are a lot of loonies. Why do I say that? Read this:
Weather Modification
They are talking about regular people that modify the weather and how the federal government is going after them with psychic atacks, etc. Ha Ha Ha Ha! I am a Chemical Engineer and I will tell you one more time, do not try this! I can go point by point and show that most (not all) of his points are totally false, but I do not have the time. Also take a look at how much MPGs were gainned by the acetone! From 35 to 50 MPG or something similar? Please...
DO NOT TRY THIS, IT MAY CAUSE SEVER DAMAGE TO YOUR FUEL SYSTEM
If you still try then so be it. Darwin would be proud. ;)
