Koing
Elite Member <br> Super Moderator<br> Health and F
- Oct 11, 2000
- 16,843
- 2
- 0
Originally posted by: xcript
Yeah, I've been doing exactly that for several years now and I'm still ~140lbs @ 6'.Originally posted by: rh71
That's BS. Doesn't work.Originally posted by: WinstonSmith
Lie around.
Don't exercise
Eat high fat foods
Go to bed on a full stomach.
Your health will go to hell in a handbasket, and you will have achieved your goal.![]()
How old are you?
Well by the time you reach 25 ish and by the lastest of 30yrs your body will be slowing down. And unless you do some physical activity you WILL PUT ON WEIGHT. Just that your body has a high metabolism at the moment. BUT IT WILL slow down and you will gain weight by the time you reach 28-32 UNLESS you exercise and watch what you eat.
If you don't count yourself lucky you won't be fat. Or rather overweight as you see a lot of guys that are thin but have pot belly's lol.
Gravity made a good point about SLEEP. You need it. 8hrs min it should be a night. Drink loads of beer also. Pretty useless calories for your system and sodas etc but in the long run the sodas are not too great for your teeth.
Got to train properly.
If your only working upper body it will struggle to pack on 20lbs.
If you work your legs and back hard you will gain much faster.
SQUAT SQUAT AND MORE SQUAT. You will pack on weight fast. Deadlift also and work on compound stuff for a solid 8months then switch it up later. But this will depend on how advanced you are.
I always tell new people to stick with:
Squat
Deadlift
Clean and Jerk (well if you want to learn to lift properly and don't mind learning technique)
Bench Press,
Pull ups,
Wide grip pull ups,
Dips
Bent forward rows,
Incline sit ups and with weights later
Hyper extensions
Bulk offs
Variety of Gymnastic conditioning
Squat 3x a week,
Bench 1x a week,
Clean and Jerk 2x a week
and pick the other exerises so you about 5 exercises a session.
ALWAYS end on back or ab work.
The rest is up to you.
And go join www.geekfitness.com as I said so and because I am a mod there
Koing
