Originally posted by: JEDIYoda
From BonzaiDuck--
I just got the unit from FedEx delivery. The heatsink-base is a very hefty chunk of copper. It makes the base of the XP120 look puny, so given the thermal resistance data and independent confirmation from another review, I have high hopes for maybe a 4 or 5F reduction in load temperature over the XP120.
Put another way, ThermalRight "wants" the SI120 to succeed the XP120, or they wouldn't be producing it. I think its appearance is timely, because of the flap about the CNPS-9500.
Actually my own take on the SI 120 is thermaltake is it is meant to co-exist with the XP 120!!
My reasoning is based on many many posts from this as well as other forums stating people would get the xp120 but it doesn`t fit there mobo...
Thus they are going after that segment of the market which is IMO quite large!
In fact you might even say they are tired of losing potential buisness to the like of Zalman and Scythe,,,etc,,,,,,
Yes I would tend to agree with you concerning the appearance of the si 120......
In fact you could say that ThermalRight made a blooper of sorts by NOT going after that market segment of those who would but can`t because of their mobo`s!!
Only time will tell!!
But its for certain other companies have benefitted from them not acting sooner!!!
Originally posted by: kamranziadar
$1600 woooooooooooowwww.
Originally posted by: biostud
I've just ordered the Asetek AT12-L30 CPU/VGA/Chipset kit with 3x120 mm radiator, I'm quite excited about mounting this once it arrives.
So did order the same radiator, from JabTech and which Asetek AT12-L30 you ordered do you have any link for that.
What the ^&%&%&^ that was amazing man 😀, but seriously i am thinking buying a Thermaltake Big Water SE, any body else has any suggestion, and great price link.
Ok i am really surprise from the results of water cooling. First of all i don;t see any improvement over the air cooling, because my XP-90 is giving me better temoerature after almost 50% overclock.
I am using XP-90 with E6 3000+ Amd vince @ 2.7ghz with 31c idle - 36c load temperatures.
So it will be stupid of me if i buy any expensive watercooling and get the same temperatures, because all the reviews and results i have seen in the last few weeks were not surprising.
Even i spend $399 for watercooling might give me 2-5c better results over my XP-90, which is totally a waste of money from my point of view.
But i really appreciate every bodies reviews,time & suggestions.
I am using XP-90 with artic silver5. I checked my motherboard temperature with various softwares like Nvidia NTune, MSI's CoreCell, In BIOS, etc all showed the same temperature.
Do you know any other way i can check it.
