kamranziadar
Banned
Ok i need help here what is the best water cooling product ever, for overlocking and for the future, plus the price will be right.
Originally posted by: HardWarrior
BD;
I'm not sure what you're trying to express here. During my time at Anadtech I've offered extensive advice about water-cooling based on my 4-years of dealing with the process. This advice has been both specific and covering the methodology itself. The OP, however, didn't ask for either of these things.
This statement/question indicates that the OP wants the "best", but at cut-rate prices, and that, in a roundabout way, he knows little about water-cooling. I responded to both clauses in the way I saw fit, as apparently did you. For the sake of comity we should just leave it at that.
Originally posted by: BonzaiDuck
No point of contention.
Originally posted by: kamranziadar1. Radiator Link
2. CPU Water Block
3. Pump
Just these three things costs me $129.
Then i realized that if i buy this
Thermaltake Bigwater 12CM Liquid cooling system $114
and add the radiator i found up there with 3 x 120mm fans i might have a winner for about $163.
What do you guys think.
