Originally posted by: iGas
I got a MJ to test out when it was beta for Canada and it worked well on a WinXP system, but too bad that MJ doesn't support Linux.
Do what I did; run XP in a VM. Using VirtualBox running headless, I used an init script to start it as a service and just RDP in whenever I need to fiddle with it. Works decent for my Skype adapter.
