IntoxicatedPuma
- Apr 21, 2012
- 125
- 0
- 76
So wrong.
That was a very detailed response full of factual evidence to prove that I am in fact wrong.
I should repeat my statement with the assumption that it is wrong, and correct it to make it sound "right".
It's almost always helping you. AWD are all full time and put power to the front wheels even if they start dont slip. Then it starts to hurt you. If you are turning in inclement weather you should have your foot on the gas pedal. Snow and ice don't exaggerate effects already taking place on the car. AWD will save you from oversteer or understeer unless if you are pushing the car at the limits, and you definitely should be doing that (pushing the car to the limits) in bad weather.
What will help you alot less than AWD, and but is not standard on every new car, is stability control. That will actually hurt in cornering by applying the brakes to the wheels and not prevent oversteering/fishtailing. AWD will NEVER help when you are accelerating, which if your car is losing control you definitely should be doing.
Sorry about that, I fixed my statement so it's so right now.
