AMD needs to do something right now, the entire AM1 line-up could be destroyed if 2980U ITX starts to show up near the 1037U prices, and lets remember there is a entire chromebook running the 2955u for just $150
Because AM1 is already on the verge of not having a market AND 2955U boxes are starting to pop up cheap, there is a Zotac with a 2957U at just $120.
And needless to say that all AM1 a little too expensive for what they are, 2650 to 5150 are a little too expensive compared to J1800/J1900, and the 5350 is causing all this disscusion of "VS 1150" because is so expensive that steps over 1150 prices.
The key here is the 2980U those 200mhz are significant for the overall MT performance.
Maybe cbn can help to reproduce their performance, they are not hard to emulate, mbs allows for changing the TDP too.
I think testing 2980U would be interesting for entry level iGPU gaming.
Not sure if it would be possible to faithfully replicate the performance though using another chip though. (re: how does someone get the iGPU turbo to act the same as 2980U using a desktop chip)
EDIT: Mayor problem in those ITX mbs are mainly intended for non-gaming, thats why we keep seeing 1037U, and thats really place AM1 in trouble too, even when we compare them to BTs.
^ This. If you intend to play games just buy a discrete card, even if it's a cheap 2nd hand 7790 on Ebay. Out of the 3 people I know who built an iGPU based rig for gaming, all 3 ended up with a discrete card less than 3 months down the line. It's not just about average fps but min fps too and when your game hits a heavy spot and slows down to 6fps, for the sake of an extra $50 for +150% performance...Seems like a pointless academic argument when you initially rule out the best option in the vast, vast majority of cases, that being a low end cpu like the 3258, i3, FX6300 or Athlon x4 760 with a discrete card.
You should had tested with 1gb ram, it s easy to set on the bios, there s inherently a menu that allow this given that the MSI has quite a complete one.
Frontpage is Baytrail C0 refresh posted.
Major takeaways:
Now supports Quicksync
Dual channel memory
Similar performance @ 10w to 25w Athlon 5350
Lower cost @ ~$70 for a J1900 (quad core) + motherboard
Not socketed, no upgrade path
Most boards use notebook memory
IGP is ~half as fast as AMD's
I think that if not planning to use the IGP, a J1900 seems a much better choice than Kabini. You get quicksync, lower power usage, and similar performance and features at a lower price. No mention of overclocking, which gives Kabini some appeal.
Get us some real FP bench, you know that 3d particle run on X87 on AMD and SSE3 on Intel CPUs.?.
It s terrible that ultra rigged benches are used to compare CPUs...
The benches on the frontpage were limited as it wasn't gaming-focused, and I wasn't aware of the large FP gap between the two.
Let s see the FP perfs with the usual suspects benches, the 5350 could be advantaged by AVX in Povray but not in CBench 11.5, dont know on R15, the new BT revision is about the same as the previous one perfs wise :
<SNIP>
