- May 30, 2004
- 7,169
- 829
- 126
After years of using different conventional cases I've decided I want something more easily accessable and better set up for frequent parts swaps. These are the three platforms I've been looking at:
HSPC Top Deck Tech Station
Pros: Less expensive then other options
Cons: Poor cooling options, no power/reset switch
DD Torture Rack
Pros: Cooling, aesthetics
Cons: Price, no power switch
Antec Skeleton
Pros: Excellent cooling, USB ports on front
Cons: Not enough room for big heatsink, short case wires, somewhat chinzy add-on card support.
I'm pretty much resigned to eliminating the Skeleton because of the limitation in heatsink choices. Anyone know how easy it is to modify so that I can fit any size cooler in there?
What do you guys think? Any first-hand experience? Any other suggestions?
DD Torture Rack
Antec Skeleton
