Best Memory to buy?
I would suggest that you go with the EL Gold or HyperX PC3500.
You will get much better timings with these and since you are using a 2.8C
you should be able to run 2X512 sticks at a 1:1 ratio.
Corsairs XMS LL is way overpriced and does not perform any better than
the HyperX from Kingston. I have 3 systems running using the C chips on
P4C800, IS7-E and P4P800. The HyperX is getting the best results.
Found some kington ram 3500 at frys, for 119$ $4 shipping.
Text
434MHz settings: 2-4-4-8-1T (CAS Latency 2)
DO you think this ram can do 2-2-2-2-5T ?
Jhites, is that the model kingston you got?
Thanks
Vito
