Best machine for cardio
If you like to bike, you can get a good resistance trainer for your bicycle for about $150.
Good call. I was strongly considering this at the beginning of the winter, before it turned out that it's been relatively mild with not much snow.
That's what I use. It works great for me, because I can utilize it with my clipless pedals and work both pushing and pulling action, which is difficult to do on an exercise bike even if it has foot straps.
what the hell is that?
C2 rower is the only one I'd consider. Amazing amount of work can be done on it in basically all time domains and it's pretty easy to maintain versus a bike/treadmill.
Running is essentially free and by far the most vigorous cardio workout you can do. P90X cannot replace running for taxing your cv system. Crossfit itself includes running, doesn't it?
As a runner, I'd like to boast this, but it's not really true. Intense cycling and rowing are just as good. Rowing frequently beats running out for calories burned per time period. Therefore running is not the "most vigorous cardio workout you can do." CrossFit entails some running, but it frequently utilizes rowing and cardiovascular conditioning through circuit-like weighted movements.
About the rowing, how do you compare it to running in terms of the workout. Should I aim for the same relative caloric expenditure as I do when I run meaning if I run at a 900c/hr burn, should I row at an equiv 900c/hr burn or should I aim for the same heart rates? Because I find that I'm unable to go as long if I row at the same HR as when I run at high intensity for 45 mins.
Firstly, 900 calories per hour is a nearly unattainable rate. I don't know if you were just throwing it out there, but if your machines say you're burning that many calories, then it's wrong beyond belief. It depends on what your goals are. If you're crosstraining and looking to change it up, it might behoove you to go harder for a shorter period of time. If we're comparing directly to running, I'd say yes - keep your HR around the same. Perhaps more important is your rate of perceived exertion (RPE). This is just how hard you're pushing yourself on a given movement (typically in %s). You're not a rower - you're a runner, I imagine. Because you're not as efficient and haven't spent as much time rowing, your muscles aren't trained for it in the right spots. Because of this, you waste a lot of energy on firing muscles that don't really need to be contracting/tight. That wastes ATP and oxygen. I'd focus on form and lower the RPE until I got the hang of it.
Also, rowing is never as comfortable as running. Your body can start firing autorhythmic cells to keep you going. Sometimes on really long runs, you forget you're even running. However, you don't really get the same thing with rowing. On top of that, you're utilizing many more muscles against a heavier load. You've gotta keep all these things in mind. Rowing and running aren't the same thing so eventually I'd row at the same RPE and try to better my times on each.
Well yea, that's what they read and also what I'm throwing out there but I know the numbers are fudged. I have a HR monitor that shows expenditure more accurately but I don't use it at the gym either(don't really care about caloric expenditure during exercise since a lot of it happens after the workout during recovery). I mostly use the numbers from the machines more as a gauge, especially the rower. Since the calories/hour fluctuates while rowing(based on exertion), I aim to stay above a certain number so I know I'm not slacking and that I'm improving over time. When I first started, the rower was showing me at a rate of 500/hr, I'm now rowing avging above 750/hr and I would try to avg higher. So whether or not I'm actually burning that is irrelevant to me, it's that I'm improving is what I use it for.
So my question was not really about caloric expenditure, it was comparison to running using this same gauge. I thought if I could pull out 900/hr on a treadmill then, I should be pulling 900/hr on a rower yet I could do 1 hr on a treadmill but can barely sustain 30 mins on a rower at 800. Then I thought maybe I should aim for the same heart rate but it's the same, I can run an hour at over 170bpm but to get to 170bpm at a rower would mean a 10 min workout. RPE seems like an interesting technique but it's not as easy as looking at a display and seeing a number and know if your'e doing better or worse than the last time.
Well, the thing is caloric expenditure is a poor measurement of performance. You should measure things like time for x amount of distance or how far you can go in x amount of time. That's a much better indicator.
I like RPE because a lot of people try to tune out of their body while working out. RPE forces you to evaluate where you are both physically and mentally and, I feel, engages you to better learn your body. If you do it for a while, you'll realize "Wow, I feel way better doing this same power output than two weeks ago. I think I need to go harder to keep at the same RPE." As a previous sprinter, our coach would yell out "80%!" We knew exactly what each of our 80%s were. They weren't all the same speed, but we all felt the same when we crossed the finish line.
I do that too but then it gets hard to compare one workout against another since I change it up all the time. One day I would work towards climbing(higher incline) while others I work on speed or endurance so that x miles over a time, etc don't translate well. So with specific workouts like best times, I keep my personal bests memorized so that my next attempt at the same exact run, I know what to aim for but when comparing different workouts on the same or different machines, I typically use the calories/hr.
Whether or not I'm good at it, I do use RPE to an extent, especially when I run outside where I don't have dials and displays to show me how hard I'm running but when I think about it at the gym, I just get a nagging feeling like I'm unsure if I'm working just as hard when comparing my rowing to running. Like you said, rowing is an entirely different beast.
Keep a workout journal. Everytime a workout repeats, compare your performance. This will be a far more useful/accurate indicator of how your workouts are affecting your fitness than measuring calories burned or even RPE.
http://rommachine.net/ Costs $14k. Some people actually have bought it.
Woah lol!
After reading through the suggestions it seems the best budget and simplest solution is the device that lets you hook up a pedal bike, think this is a good way to go? Or would a treadmill be better? I'm sure I can find a second hand one for a few hundred bucks. I like the idea of the bike though since I can vary the load on it by shifting gears, and maybe even adding magnets and coils to generate power and add loads that way too. I would either use my existing bike or just buy a cheap bike for it. I'm guessing assembly is quite easy.
The beauty with this is my basement is cool so think I would be able to push myself further then if I used gym equipment, and I see people fighting all the time for the cardio machines I rather not even get into that fiasco.
Come to think of it, do they make heart rate sensors that I could use? If not maybe a real exercise bike will be a better idea. Just something nice to be able to monitor, and I'm sure some have other stats too like the distance and such... I just realized that now. Always fun stuff to be able to look at.
900 cal per hour is FAR from unatainable. The avg male burns about 100-115 cal per mile. Run at 9mph and presto! Also, rowing on the C2 at about 2:06 pace per 500m will burn about the same.
Source for those numbers?
Lol. What is this average male? How do you calculate calories burnt per distance? I can walk, walk fast, jog, jog fast, run, and sprint. These all have HUGE sways in calories burnt per mile so I'm first gonna call measuring calories per distance a really bad way to calculate calorie use. Secondly, do you know many people who can run 9mph for an hour? It's not impossible, but few weekday athletes will achieve that (especially if they're not running specialists). I'd also like to see somebody maintain ~2min per 500m for an hour on the erg. I know that you CAN burn over 900 calories per hour, but it's not very common that the average athlete does (again, unless it's a trained endurance athlete).
