Originally posted by: BoberFett
Originally posted by: mboy
Talk about puckered A$$hole$. AND who made u the master of defining hardware? Guess no one because u need help picking ram for a Dell server!
Do you even know the difference between ROUTING and filtering? Guess not. Your career as a network admin was over before it started. (and server admin to boot).
Wow, talk about a jerkoff with no life. Stalk much? Would you like to dig through my garbage? I can send you my old underwear so you can sniff it, you freak.
Originally posted by: Johnbear007
this thread has gotten seriously retarded.
Yawn 😛 (Everyone else understood my use of caps .... when you can addres our point(s) let us know or not ... either way this thread is basically over the guy has his answer)Originally posted by: BoberFett
Thorin
5th reply to this thread. By you. In big CAPITAL LETTERS! You got rather upset at the notion that somebody was trying to pass off a home broadband router as having firewall capabilities. Who's bitchy?
Originally posted by: Dug
mmm...
So for $20 I have a Router that can-
Allow and deny IP ranges
IP filters
Mac filters
URL and domain filters
Set up individual firewall configurations manually
All can be configured on a schedule for any time and date
It logs
System activity
Debug info
Attacks
Dropped packets
and can all be emailed to me if I want.
Block wan pings
VPN logging and blocking
virtual server setup with an IP outside the rest of my internal netowork.
web based configuration
remote management
All for $20, I don't see much reason to spend money on a firewall for a home user.
I thought all routers did this, at least my last two have.
Originally posted by: desy
Not interested in SW based one I don't see how they could be as good as a HW one and if you have a updated Virus product its kind of redundant isn't it?
I've seen Sonicwall but $$
So who makes a good one thats good for home use?
I've got soooo many staff who have come to me since high speed has hit the sticks out here with monthly virus crashes they are starting to suck up all my time for none work related issues!!
Software is as good or better IMO... reason being a software one will tell you exactly what programs are trying to access something etc...
Disagree. I can shut down a software based firewall with a 1 line batch script. Try shutting down my sonicwall.
True but it is much much much harder to gain access to a HW FW to shut it's software (firmware) down (which would likely actually cause it to crash and go offline which would be next to useless to an intruder/attacker) then it is to gain access to a Winblows box with a trojan or other vulnerability and shutdown a SW FW that might be running. Plus by the time I get in to shutdown a SW FW I'm "standing in the living room" whereas with a HW FW if I get to shutdown it's software then I'm still standing at the door.Originally posted by: Regs
I don't get that logic. A hardware based firewall... that's just a computer with only one purpose and that is to serve as a firewall. How is a computer with firewall software any different then a separate piece of hardware with firewall software like a Lynksys router?Originally posted by: mboy
That's all a firewall is, software on hardware. Hardware is useless without software or some type of programming. Just like a video card without HDL . If you can disable a firewall on a computer then you can damn sure disable one on a router or other related equipment.
Originally posted by: Tabb
Is it safe to say smoothwall running on a dedicated computer is better than Zone Alarm Pro?
