Originally posted by: BoberFett
Only on the internet.![]()
Q: "So what kind of firewall should I use to protect my eMachine at home?"
A: "First you need to get rid of the eMachine and build yourself a Dual Xeon 3.06 with a Geforce 5900. Then install download an ISO of one of the linux distros. Be sure to compile it with only the options you need to conserve RAM. Then just get yourself a Cisco Catalyst and Pix."
Originally posted by: Dug
Where are you getting your definition of firewall?
And what feature is needed in a router to be able to call it a firewall?
Because every definition I've found so far for firewall basically describes what most consumer routers do.
Yep, used it for 3-4 months, and I loved it. VERY easy to set up, and a nice web based interface.Originally posted by: Tabb
Anyone have any comments on smoothwall? SmoothWall
mboy
So unless it's a Sidewinder, it's not a realy firewall? I've been looking at 32 way Xeon boxes from Unisys recently for work, and EMC fiber channel arrays. That's a real compouter. All you pathetic wankers around here with your single processors and RAID 0 aren't really using computers.
What a joke. Get over yourself.![]()
So I guess you aren't using a computer because it doesn't have vacuum tubes and punchcards?
Definitions change. Get used to it.
Originally posted by: desy
OK it went around consensus seems HW is better, like I asked , so how much is a HW firewall.
I thought of a NAT box as well but like you all said weak, they aren't opposed to spending the money she's a doctor
They already have Mcaffee on and updated daily which has been doing the job this last week detecting and deleting files.
I just wanted to know what was the best bang for buck personal HW firewall.
Shes not a bad user just getting a lot of hacks into her system from a cable modem, I told them they shoulda went with DSL but some never listen.
mboy
Where in my post did I say that? I was giving an extreme on a LARGE Enterprise firewall.
A Cisco PIX, a Sonicwall, Checkpoint-Those are firewalls. Your little $20 linksys ehterfast router isnt't.
Myabe u should get over the fact that a NAT box isn't a true firewall. Do u work for Linklsys or something?
Smoothwall, altho I never used it, I hear is pretty good. A hardened linux distro turned into a firewall only.
Is it JUST POSSIBLE that there are different levels of firewalls? The lowest of those being cheap home routers?
I've never seen such a bunch of puckered assholes in my life. Who the hell made you lords of masters of defining computer hardware?
Originally posted by: Macro2
I feel so fortunate, my router can block outgoing as well as incoming...
Source address, Destination address, port, protocol etc. Ahh.
Mac
Seems around here DSL seems better than cable .Even the cable provider itself said after last week the bug was inside its firewall and they had trouble blocking it.
So next question is a Linksys NAT/Firewall better than SW only firewall?
YesOriginally posted by: BoberFett
NoThe lowest of those being cheap home routers?
I AM the F'ing master of the UNIVERSE haven't you heard?I've never seen such a bunch of puckered assholes in my life. Who the hell made you lords of masters of defining computer hardware?
That's truely sad.Originally posted by: desy
Firewall yes (ie: BEFSX41) but router that supports NAT (ie: BEFSR41) not necessarily. Your best bet is either a HW Firewall (like the SX) or a Router that does NAT (like the SR) and a SW Firewall (make sure you get one that does both inbound and outbound traffic ... more info).So next question is a Linksys NAT/Firewall better than SW only firewall?
Talk about puckered A$$hole$. AND who made u the master of defining hardware? Guess no one because u need help picking ram for a Dell server!
Do you even know the difference between ROUTING and filtering? Guess not. Your career as a network admin was over before it started. (and server admin to boot).
Originally posted by: WarCon
Surprised no one suggested digging out an old Pentium/Pentium II class machine out of the trash or from some place like Goodwill for $25 and putting two cheap NIC's in it and setting up a secured Linux box. Be pretty cheap, just needs a bit of Linux expertise.
P.S. if anyone has a quick setup guide for something like this I would appreciate it as I am not good in Linux. (Can barely get it installed and hooked to the internet before I give up on it 🙂 )
