WHipLAsh13
- Jan 17, 2001
- 1,719
- 0
- 76
Originally posted by: Overkast
I see.
Let me ask you this.... what mouse pad do you recommend for the best precision tracking? I'm a graphic artist, so precision is crucial to me, but I also like to game as well.
I saw the review on the Everglide being a good pad for gaming, but not necessarily precision tracking. I need the best of both worlds.
Any recommendations? I'd like to get a sweet mouse pad and put the C4 on it for optimal tracking results.
Money is not an issue.
I see.
I see.
Try cloth. It may not have the "speed" of a hard pad, but it's very accurate. A good mouse is also important. I found that the Intellimouse Explorer 3.0 tracked poorly when moving the mouse slowly, something that you're bound to do when working with graphics. My Logitech mouseman dual optical is great at slow speeds. The MX700 I tried was also, but was too heavy for me.
Sounds like a real solid plan... thanks for the tips Johnbear007. I think I'll go fo it.
I was going to purchase the Bluteooth wireless keyboard/mouse set for myself for christmas this year.... is the mx700 the same mouse that's included in that set?
It looks like it is.
I see.
Okay, I did some quick research, and here's the setup I think I'm gonna purchase this season:
-Logitech® Cordless MX? Duo Wireless Keyboard/Mouse Set (mx700 rechargeable mouse).
-Everglide Ricochet 2.52 mousepad (Lava Black)
-CS Hyde C4
-CS Hyde Teflon Mouse Tape
Comments? Suggestions?
-CS Hyde C4
Originally posted by: Shanti
I've always been satisfied with the cheap cloth pads with my MS Optical. I like the way they feel better than the plastic type pads.
I'm pretty careful anyway, so I'll most likely get the 16 x 16. Thank again for the advice.
One more question for ya and then I'll leave you alone... Do you know how long is the mx700's battery life?
Is it possible to have more than 1 mx700 set up to use the same PC? So say I start to wear down one of the mx700's battery life, I can just dock it and pick up the other one and continue working.
Is that possible?
I used 3 Intellimouse Explorer 3.0s before I gave up on them. They tended to "jerk" all of a sudden when moving the cursor from a standstill. My roommate swore by his though, so this may be a matter of preference.
My cloth pad is about 3 or 4 years old and still performs as it did when I bought it. Dirty? Sure. Dirty to the point where it affects performance? Heck no. The bottom part is just now starting to separate from the foam if you pick at it. I can always turn the pad 180 degrees before wearing it out completely. In addition to the great tracking and optical friendly surface, it feels nice on my hand and the fact that it's flexible makes it easier to carry to a lan.![]()
Cloth pads of years gone by were indeed inferior. I got one with my first computer in 97 and it crapped out in less than a year before becoming heavily stained and almost rough before I chucked it. Newer pads are relatively thin and durable. Good stuff!
Hmmm , I can understand having one for the comfort factor. However as far as tracking goes, I still haven't come across anything that tracks like the C4
