Bathtub Made out of Tile??
Nebor
29,582
12
I'm no Bob Villa, but those two options shouldn't cost the same amount of money.
SagaLore
24,036
21
I haven't even heard of bathtubs being made out of tile. That's just crazy.
Turin39789
12,218
8
I don't think I'd buy a house with a tile bathtub, unless it was cheap enough for me to budget ripping it out and putting in a proper tub.
PsiStar
1,184
Just because it takes a lot of work & even if it skilled workmanship does not mean it is any good. If you want good you need to check out a place in your area (where ever that is) like this ... it is not your daddy's hardware store. It is where you go when money is no object and you do get what you pay for.
HelloWorl
385
Huh...we don't like those bathrooms at all really. This is going to be hard deciding what to get.
paperfist
6,539
287
www.the-teh.com
Looks nice, but that's just the outside. The inside isn't tile, which is what they want to do with our bathroom.
I think I'm going to try to push to get them to put in a pre-made one and see what we can do.
Yeah I know, I was just illustrating that you can have curves made out of tile...
Sep 12, 2004
16,852
59
86
It shouldn't be that hard. Designing is not all that difficult. Consider it like a tree. Determine a couple of primary things first then branch out from there. The first two consideration are:
1) Basic style
2) The color scheme
For style, what do you prefer? Modern, traditional, country, European, Asian, eclectic, ect.
Pick a major theme then determine your color scheme. After that, decide if you want a dual vanity sink, single vanity sink, corner sink vanity, pedestal sinks, etc.
Your biggest decision is what you're going to do with the tub area. Do you actually take a full bath very often? If you're more of a shower person you might want to consider the various shower options first. Have you considered a glassed-in shower where there are multi-zone shower heads? imo, that kind of setup blows a tub completely away, even jacuzzi tubs.
