Bare-die testing: A delidded 3770k, an H100, and 9 different TIMs
crashtech
10,695
2,293
I think I am confused (no big surprise there :)), but how does he reuse all the stock hardware (except the backplate) when it is the stock standoff pins (the height) that are the problem in the first place?
All I replaced were the stock standoff pins. I'm quite baffled to think how one would be able to salvage using the same standoff pins but not be able to use the stock backplate :confused:
What am I missing here?
Maybe I'm missing something, too, but the designs I have worked with have fasteners with a threaded portion that ends abruptly with an increase in shank diameter. The non-threaded portion acts to set the spring preload. My assumption is that the washers had an ID large enough to allow the non-threaded shank to pass through, thereby effectively shortening the shank and increasing spring preload, or in this case, bringing the water block closer to the board while maintaining acceptable preload.
24HZ
52
This is correct. The H110 doesn't work the same as the H100. Also, I'm not really losing anything from spacing the backplate as the H110 backplate is made of super flexible plastic so its not really adding any rigidity even when up against the motherboard. I still have the CPU plate though.
...but how does he reuse all the stock hardware (except the backplate) when it is the stock standoff pins (the height) that are the problem in the first place?
The H110(and similar newer Corsair blocks) don't use standoffs like the H100.
Those posts have internal springs and thread right into the backplate 'nuts'. The posts are designed to 'bottom out' (the thread, not the spring) so you know when you're at the right tension when you can't turn them anymore. By moving the backplate and nuts 3mm further from the board, I've just added 3mm of additional preload on the springs to compensate for the 2.5mm lost to the IHS being absent. So an additional 0.5mm above factory spec which ended up being fine.
Idontcare
21,110
64
Ah, I understand perfectly now! Definitely a cool mod on your part and I totally see now why you did what you did :thumbsup: Nicely done :cool:
24HZ
52
I wish there weren't so many different ways to do this but with all the different mounts on the market it makes it difficult to come up with a blanket solution. I just hope our diagrams and guides will help get the word out enough that Intel stops making us do this in the first place.
Phynaz
10,140
819
I know it isn't popular to talk about it, but that is basically what an Itanium-like microarchitecture would do. Double or quadruple the width, drop the clockspeeds so power stays reasonable, and get the compilers to do more work for you.
I said it years ago , and I still believe this is where the future of computing lies.
hawtdawg
1,223
7
Some of those temps seem pretty high. I have a 3770K delided with CL liquid pro between the core and IHS, and MX-4 between the IHS and my NH-D14, and 4.6@1.35v barely breaks 70C with IBT max. He gets similar temps with 4.5@1.183 with MX-4. My ambient is 24-25C as well.
wand3r3r
3,180
This thread is just awesome. It should be on the AT site itself. Great job Idontcare! Another great examination with all of the relevant details meticulously recorded (and explained).
l0rdraiden
I have read almost the whole thread and I still have some questions my apologise in advance because since I'm not native English I may have asking things somehow already explained.
I have seen this video about CLU
https://www.youtube.com/watch?v=jNgIQQcUSDM
And I guess the same thing happens with CLP and metal pad
Have you experience the same? after a year or so will I have to re-apply again a new thermal compound? any solution or workaround? Would be better to get MX-4 or PK1?
http://www.vortez.net/articles_pages/arctic_mx_4_thermal_paste_review.html
http://skinneelabs.com/2011-thermal-paste-review-comparison/2/
On the other hand I would appreciate if somebody can explain what is the pump-out effect? does this happens with only with heavy air coolers? does a watter block avoid this?
Mounting a heavy air cooler (vertical tower) in a bare-die wouldn't be dangerous?
Can anyone tell me what is the safest way (what is needed) to do a bare-die build? I think one example has been already explained by 24Hz, but it would be nice to have a standard alternative explained with pictures and step by step
Does it worth to mount it naked? I have seen that the difference is only 2 or 3 degrees
And regarding this: http://www.ekwb.com/shop/ek-supremacy-precisemount-add-on-naked-ivy.html
I guess is only compatible with EK water blocks right?
Thanks in advance
Idontcare
21,110
64
From a previous post of mine in a different thread:
One is the push-pull pumping effect that comes with the mechanical expansion and contraction of the silicon, the TIM, and the overhead IHS. Eventually, given time, the TIM itself will be squeezed out of the gap that it occupies between the die and the IHS and an air gap will be left in its place. The air gap most likely forms when the CPU cools down.
Then when the CPU heats back up, the air gap prevents the IHS from heating up in concert with the die and the TIM, resulting in an IHS that is not expanding to fill in the air gap, leaving the CPU much hotter than before.
I have not had any issues with CLU needing to be re-applied. The liquid ultra itself does not contain any volatile components that could evaporate and dry out.
But being a liquid metal, it is prone to oxidizing and becoming a metal oxide (which won't be a liquid anymore, and won't have good thermal conductivity either).
If you are specifically looking to avoid the pump-out effect then you should look into IC Diamond as they tested it for pump-out and claim (check their website for the study details) that ICD prevents pump-out.
24HZ
52
This shouldn't be a problem when delidded right? With the adhesive removed, there's a constant down pressure due to the mounting mech. Even if some of the TIM gets pushed out, the down pressure should keep any air gaps from forming and the mounting mech should 'absorb' some of the added pressure from the expansion. The TIM should get thinner and thinner until the added pressure from the expanding parts doesn't really squeeze any TIM out and the cooldown phase should suck some the TIM back in on the edges. Perhaps the edges will see the worst degradation but that shouldn't affect performance all that much.
Idontcare
21,110
64
That is the idea, keep the TIM under a state of constant compression (be it hot or cold) and there is no opportunity for pump-out to become a problem.
Yes some TIM gets pumped out, but it isn't backfilled with an air gap, rather it gets backfilled by the physical displacement of the HSF block itself (which moves ever so slightly closer to the bare die).
24HZ
52
I mean, this is probably the same reason why using overly excessive amounts of TIM doesn't really matter. It will eventually settle to the same thickness.
I never liked the old warning of use the right amount of TIM or else you'll get horrible temps even worse than using no TIM at all. Yeah its good practice but its not nearly as horrible as people made it out to be and I never believed it considering how viscous TIMs were there was no way an excessive amount could have stood up to the mounting pressure of any historical mount.
Idontcare
21,110
64
You mean something like this o_O :D
treeofwisdom
Hi All,
After viewing this forum and this other forum link, I decided to get a 4770 (VM machine) and a 4770k (gaming/PROD machine) and delid them.
The first one is the 4770.
Managed not to get a picture of temps before, and I do remember them being around 76C with the last core being around 65C.
As the images will show, it gets a lot better with a bit of CoolLaboratory Ultra and MX-4 for some direct die air cooling.
Enjoy! I will post again with 4770 k delidding etc.
I am loving it after I shut down my core 2 quad 2.83 GHz system.
Idontcare
21,110
64
Welcome to the forums treeofwisdom! :thumbsup:
Hi All,
Very nice :cool: Very nice indeed :)
PPB
1,118
168
Any opinions on the vice method? Anyone tried it and cant tell their experience on the subject? Plan on delidding if i see that temps are really that bad on my 212+
Idontcare
21,110
64
Haven't tried it but IMO it looks extremely risky because you don't have much travel room before the side of the internal cavity of the IHS slams against the side of the CPU silicon.
treeofwisdom
I de-lidded mine with a vice like the youtube video below:
youtube link
When I was practicing, some of the chips required 1 or 2 solid hits and they were off. One thing to remember is to not heat the chips up on the stove before this operation as the sticky glue/silicon simply resettles into place and makes it even harder.
It's all about shear force.
Look at the extreme right processor, it was my old Core 2 quad which was
soldered. I managed to rip it in two right through it's centre...
The rest of the chips are dual core e6500/e6400's etc from old machines. I would highly recommend searching for the relevant processors and practicing before putting the 350+ $ chip on the vice.
Aikouka
30,383
912
After seeing some talk about this, I'm rather tempted to at least delid and apply better TIM. Although, my only question is which TIM? Everyone seems to suggest CLU, but I've already got Prolimatech PK-3 lying around. IDC, your tests showed that CLU was comparable to NT-H1, and other benchmarks show NT-H1 as being comparable to PK-3. So, it might just be worthwhile to use PK-3 instead of spending even more on CLU.
I'm not sure which removal technique (razor vs. vise) that I'd use. I've seen quite a few comments about how easy and painless delidding is with the vise method on a newer (Ivy Bridge or Haswell) processor.
crashtech
10,695
2,293
If I try it, I'm going to use the plastic jaw protectors on my vise, and use it to hold the CPU steady while slicing the glue with a razor. I don't like the prospect of sending a de-lidded CPU flying.
PPB
1,118
168
I have seen some people put an anti static bag (those from used mobos come in handy I guess) on the other end of the table so if you overdo it when slamming the die and goes flying the bag can at least catch it without any worries.
A method mixing the vice (to hold the processor steady) and the razor's seems like the best overall choice. Seems like 5 yrs of cutting materials to make building's models for college might pay off :biggrin:
caution
37
Thumbs up for the topic starter.
Nothing special to add to the thread rather than that anyone thinking about regluing the IHS, black RTV silicone is indeed, the way to go.
3 months and things just look still great :)
Aikouka
30,383
912
I don't see why you couldn't clamp a large bag onto the opposing end of the vise, so if the processor goes flying, the bag will catch it.
