The Sauce
- Oct 31, 1999
- 4,741
- 34
- 91
I have been using the Manta since my squat weights started getting up there. Wouldn't squat without it now. When I started out and was squatting light I had it on my shoulders bare, but when I rack 400lbs+ my traps feel like they are ripping off and I sometimes get this "oh shit" moment when it feels like the weight is rolling off backwards, causing me to torque my back to correct. The Manta definitely makes it safer and prevents that from happening. It in no way prevents proper "bar placement," form or stabilizer muscle "tightness" - that would be a Smith Machine. The bar is in the exact same place, just maybe 1cm higher off your shoulders due to the thickness of the device.
If you are lifting light and your shoulders hurt then you are probably just a puss. IF you are going heavy, put a pad or some other device on there. IMO.
