Bagels
darkxshade
13,749
My question to you is, why does it bother you? Big deal, you rip it apart.
I don't know why but it bothers me too, especially those ones that when you try to rip apart causes the O on the bagel to break after you separate them because a chunk of the top is still stuck to the bottom.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Because one of the ones I just had was a pita to rip apart without shredding the thing. It was the occasional far less than 95% cut bagel. I almost grabbed a knife, but some my mind suddenly had some recollection about how dangerous it is to cut bagels with knives.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Also, how dangerous it is to be around you with a knife period:hmm:
Ika
14,264
although it does allow for the use of those nifty bagel slicers, which I like using very very much. :awe:
guyver01
22,135
61
not if you use a miter.
quikah
4,228
770
You have a line of bagels on the conveyor in the bakery. They head to the slicer and get cut all the way. You now have tops and bottoms all over the place when they are put into the bags.
Instead you cut so the top and bottom are still attached. They now neatly file into the bags.
That is my guess anyway.
Lifted
5,748
You live in NY and admit to buying mass produced bagels?
Even worse, you're complaining about the way they're sliced instead of the way they taste!
I hope you don't consider yourself a real New Yorker!!!!
:awe:
BurnItDwn
26,379
1,887
:awe:
Well ... he is in rural western NY, which to my knowledge is much much different vs NYC.... probably cheaper to buy packages of bagels at the store vs going to an expensive bagel joint. Also, he may not have a good local bagel joint.
Kelvrick
18,422
I don't like it because it makes it harder for me to smoothly apply my cream cheese. I have to make it for it by piling even more cream cheese on.
Bagel companies are why I'm fat!
lokiju
18,526
Depends where you get them from.
The Panarabread ones tend to be cut all the way through.
SonicIce
4,771
this is probably the answer
preCRT
2,340
123
Only idiots slash themselves while cutting bagels.
:awe:
Goyim, and they slather them with mayonnaise.
The OP is full of FAIL
Andy22
1,425
Interesting thread. I have been on a bagel kick lately. A sandwich made with a bagel just seems much more appetizing. I like Turkey and cream cheese or even peanut-butter and cream cheese. Sounds gross but the cream cheese smooths out the peanut-butter and makes for a filling meal.
PingSpike
21,766
615
The fact that you rejected all of the answers you already found online does not make those answers incorrect. It is you that are incorrect, sir. Bagel half matching is a perfectly reasonable goal.
PingSpike
21,766
615
Don't you run your own farm and do all your house and car repairs? But you've been defeated by the task of cutting a bagel scrap with a knife? I guess every super hero has his weakness. Superman has a green element from his home planet, DrPizza has boiled breads.
JS80
26,271
7
it's so the bagel cutter blades do not wear down. A different blade is used, coming from either side of the bagel, compared to bread and other baked goods; when the blades come down to cut the bagel, they go through from either side and they found it was causing too much wear on the blades when pushing them all the way through, since they would of course make contact.
The solution to this was to stop the blades at the midway point, which still allows the consumer to easily finish off the cut themselves, while at the same time conserving the blades for a longer period. Some companies do a better job than others, but generally i do not find it to be too difficult to pry the two halves apart and if it keeps the cost of bagels down, i'm all for it.
Kt
shens
preCRT
2,340
123
I hope to hell the OP isn't confusing that Lender's crap with real bagels.
vi edit
62,484
8,345
They are cut all the way through because they only cut them 1/4 of the way down. So you get the top of a bagel that's like a 1/2 slice of bread in the middle narrowing down to the thickness of a potato chip at the sides...while the bottom is like two slices of bread thick all the way through.
And they always do that on my favorite ones like the cinnamon crunch and some bastard steals the crunch laden goodness top out of the box and you get the leftover cinnamon crunchless bottom.
