AutoZone no longer loan out the check engine light box :(
Possessed Freak
6,045
Originally posted by: Feanor727
If you have OBD-II, then the only way to read the fault code is with the code-reading device mentioned elsewhere in this thread. As has been mentioned, you can buy one for under $100. If you plan to keep the car, then just break down and buy one - it's well worth the cost, especially if parts stores in CA can't legally offer a free read.
This is not always the case. My 2003 PT had a shortcut to read the codes (involved turning the key in a certain pattern). Very useful.
slag
10,473
Originally posted by: bruceb
Autotap does work with a laptop computer. That is why it is relatively cheap, compared to say, a GM Tech II tool or a Ford dealer type tool.
yep.. i have one and it works well.
Also, my 96 maxima worked by turning the screw on the side of the PCM under the heater area. and it was obdcII.
dawp
11,347
2,710
yup, On my 2004 Toyota, I just have to jumper between 2 slots on the OBD port to get the code. I'd get your self a repair manual as it will tell you what you need to do to get the code. cost about $20 and may come in handy in the future.
Capt Caveman
34,543
651
fwiw - in Boston, I've been hearing radio commercials by Autozone promoting that they provide free Check Engine light code reads
