Ok. I should be cruising in the small D right? Is the Big-D just more torque?
No it's going to provide the least amount of power of all your gears it's only really for cruising purposes (Above 45-55 depending on your gear ratio's), If your Towing/Hauling/Passing you shouldn't even use this gear at all. When you mash on the padal to pass it'll drop right out of OD.
It was a rhetorical question
Oh
Oh
