Audio and HDMI questions.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
I never really thought about it, but as a temporary solution I suppose I could use component (those are the red/white I think) cables to run from the Xbox to the receiver, leaving the other optical and HDMI slots for the Blu-ray player and cable box.
It will only be used for Kinect games, but I assume there would be a pretty massive degradation in quality doing that?
KT
Phanuel
2,304
KT
Red and white are the left and right channels for audio. Component is 3 cables, http://upload.wikimedia.org/wikiped...mponent-cables.jpg/220px-Component-cables.jpg it is HD. But now you're just going to have to deal with switching TV inputs and receiver inputs as well to get Video and Audio.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Phanuel
2,304
Ah ok, thanks, I'm such a noob. :D
I think the $250 is probably worth alleviating that annoyance and having everything go through HDMI/Optical. :hmm:
KT
That's the reason I replaced my 4 year old Denon. It only had 2 HDMI inputs and I had 3-4 devices I needed to hook up. It's disposable tech man! :p
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Heh, yeah, so true. I just reserved the $250 receiver, so can pick it up later. Thanks again for all of the help. :)
Now to determine whether the 4GB is enough for the Xbox, or if we need to return it for one with a bigger drive. :hmm:
KT
purbeast0
53,637
6,518
you can use usb hdd's for the 360 just fyi.
i'm also not sure why you wouldn't be getting sound out of the hdmi cable. you shouldn't need hdmi + optical to get sound at all. hdmi should be just fine for the sound, even surround sound.
(i didn't read the whole thread not sure if you already went over this)
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Oh right, did not really think of that. I have a USB 3.0 1TB external drive that could do the trick. I assume it's not much of a hassle to set that up?
Yeah Phanuel informed me that my receiver sucks, that's why it doesn't work. :D
KT
Phanuel
2,304
An external HD for an Xbox will only be useable for reading media files off of (music/videos) and maybe storing game save files to. You won't be able to install any games or apps to it as far as I'm aware. You'll need the internal drive for that sort of thing.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Ah ok, well that seems less useful then. I'll have to find more information on that. Thanks.
KT
Feb 6, 2007
16,432
I've got an old Onkyo that only has 2 HDMI ports. I just got one of those HDMI switches from Monoprice, so hopefully that does the trick; $25 is a lot nicer than $300+ to replace the receiver.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Ok, so I got the receiver home and set-up; works like a charm! It even sounds louder, which is great. Before I had to crank it all the time and not having to switch around my inputs every time I did something is awesome.
One question though, I now have an extra device that requires an ethernet connection, but I do not have any additional plugs around. I looked around at switches and they all look to be huge; does anyone know of a small (say 1 input, two output) switch that I can use, or any other alternative that would work here? Essentially have ethernet from wall needing to go to Blu-ray player and Xbox (so freaking obnoxious that the Xbox does not come with built-in wi-fi).
Thanks!
KT
Drako
10,697
161
Thanks!
KT
Just get a cheapie hub, you don't need a switch for that.
Feb 6, 2007
16,432
Thanks!
KT
The current generation of 360s all have built-in WiFi. How old is yours?
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Oh snap, I am sofa king we Todd did
The new Xbox 360® 4GB Console. Here today, ready for tomorrow with a brand new, leaner machine. Wi-Fi is built in for easier connection to the world of entertainment on Xbox LIVE, where HD movies and TV stream in an instant. It’s ready for the controller-free experiences of Kinect—you don’t just play the game, you are the game. Xbox 360 is more games, entertainment, and fun.
I'm going that way fer sure. Thanks again to all of you for the help!
KT
