LiuKangBakinPie
I think using heatguns or whatever burners won't help with Pop Tarts. I think you will just burn her face. Her pimp will be fucked off at you.
I have an idea, entirely untested:
Find a sheet of glass. Heat glass in microwave (timing unknown). Open, test heat (drops of water should boil quickly), put pop-tart on glass, remove pop-tart, repeat for other side.
Make sure the room doesn't have a smoke alarm right over the microwave. 🙂
OMG, I didn't think of this! Grab an extension cord, cut the end off. Stick the wires into opposite ends of your pop tart. Plug in the extension cord. When the pop tart appears hot enough, unplug the extension cord. Enjoy!
I'll be doing an experiment on parallel and series circuits later this week by doing exactly that with hotdogs (except I impale the hotdogs on nails that are connected to the extension cord.)
You think glass will heat in a microwave?
I don't think there's enough salt in a pop tart to produce notable heating even at 240V.
Oh and since that was brought up, cannot forget this!
http://www.youtube.com/watch?v=hvS6bOKLhFs
Some types of glass will get very hot in a microwave, but most don't.
🙂 That's how we cook the hotdogs in class. (Although, 2 at a time; sometimes in series, sometimes in parallel.) At 120V, it takes approximately 90 seconds before a Ball Park frank splits open. (And, as expected, a little over 6 minutes in series, since they split the voltage & with twice the resistance, there's only half the current. So, P=VI = (1/2V*1/2I)=1/4 the power for each hotdog. And, of course, with the increase in time, there's an increase in the total amount of heat that's radiated away, adding a few seconds to the total time, or so I presume. Of course, the difference could be from an effect of temperature on the resistivity of a hotdog. I should test that some day.
Lower the power level on the microwave to like 10% and microwave for about 15 seconds
Start car, place poptart still in pouch on top of car engine. Give it a couple of minutes.
Your options are stop being cheap and spend the $10 for a toaster.
Could be banned.
I can't have a personal toaster.
(That's what prescotts are for!) 😛
Plugging any kind of heater into a UPS is generally a bad idea too. 😉
Have you found a way to prevent the scorch marks around the nails ? I prefer to cook mine using DC vs AC , just a taste preference 😀
Increase the surface area using really wide spikes. Presto came up with this idea in the 70s with their hot dogger. Will cook five dogs at a time in just 60 seconds to feed a family. Runs on 120VAC in North America. http://www.youtube.com/watch?v=aUAkezGstlQ
Back in the 1970s microwave ovens (radarrange hehe) were EXPENSIVE!
Higher frequency would probably be a little better. Easy enough to do with a signal genny and powersoft 10K amp here.
I never knew they made a retail product out of the idea, nice, bet it had some serious safety issues though.
My grandmother had one of the first ones. It took up the entire counter and even stuck out because it was so deep . It was made by Amana.
A new use for function generators ! Does sine wave taste better than square, what about triangle ?
