One of my favorite things to make is beef short ribs. They are incredibly tasty, and everyone who has ever had it loves it. It's also very easy to do, but people will think you're some kind of Iron Chef because it's so good.
First get a pot large enough to hold all of the short ribs laid flat on the bottom. Generally I do four. This is your "main pot" that will hold everything and go in the oven.
Get another pot and fill it with chicken stock, you will need enough stock to cover everything completely, this amount depends on your pot, meat, vegetables, etc.
Bring the stock to a boil and let it simmer on low until you need it later.
Vegetables
Anything you want really. I use carrots, celery, potatos, and onions. Chop them up and just sweat them while you do everything else. (keep on low heat, a little bit of browning but not much)
Extra Spices
You can take some cheese cloth and wrap some spices in there. I use a whole head of garlic, bay leaves, peppercorns, tyme. Just tie up the bag, save for later.
The Short Ribs
You can season your short ribs before searing. I use a little kosher salt, some garlic pepper, things like that. Don't go too heavy though.
Take your main pot and put it on high heat with some oil. Sear the short ribs for about 1min top and bottom, you want a nice crust to form.
Put your seared short ribs on a plate and cover them with foil for now.
Deglaze the pot you just seared the ribs in. This is a key step in getting that wonderful flavor. Use 2 or 3 cups of decent red wine, something you wouldn't mind drinking. Just pour it in the hot pot, and stir and scrape everything off the bottom with a wooden spoon. Let it simmer until the wine is reduced to about half what you started with.
Add in the vegetables you had simmering. Stir them around so they cover the bottom evenly.
Add in the short ribs.
Put your spice bag on top. Cover the pot and put foil over the cover and seal the edges. Place in oven for at least 6hrs, up to 8hrs at 300-350F
6-8 hours later...
Take out your pot. Remove the ribs. Strain the liquid into another pot, save the vegetables (sooo tasty). Take half of that liquid and put it into a pot and boil it. Reduce it down until it starts to get thick. This becomes the most wonderful glaze ever. This takes about 20-30mins, but it's worth it.
Serve. I like to serve a whole short rib with some of the vegetables. Either put the glaze on beforehand or just put that in a bowl on the table and let you guests use it. They won't need knives, the meat is so tender it breaks apart with a fork.
Oh and that whole head of garlic that was in there, yes, very tasty, very very tasty....mmmm
I think that covers it, let me know if you have a question.
