ATI 5870 specs?
Originally posted by: MODEL3
And since what I proposed was essentially something like a DX11 4770X2 (32/64/1280)single GPU, my estimation for my scenario was around 300-315mm2 at 40nm, which is big enough! (5/3 - 7/4 , long talk again)
So 300-315mm is so much bigger compared to RV770 256mm? By going by the specs I estimate around 300mm too and I consider a slightly bigger.
In no way i'm implying that i am right and you are wrong, i just wanted to show you the way of my thinking!
It was never about who is right or wrong here. However I happen to disagree with your assessment about 5870? being big. What would you call GT200 chips? Now that's a big chip. X2 would be feasible at 300mm or so and looking at the yields of 4890 and 4770. 900-950mhz isn't out of the question either.
But we agree!
Please look again my previous reply where I said that:
I agree with your point that :
It's actually quite acceptable considering it will be on 40nm.
The italics text above was what you said in your reply, about the 5870 specs that the site suggests!
My previous reply had focus to show that I said "big" in a sense:
that will be difficult for ATI to hit 900Mhz on the standard configuration (like the site suggest) :
1.Since their proposed die is a little bit larger than my scenario's die
and
2. In my scenario i find it difficult for ATI to hit 900MHz,
why in their scenario the 5870 can hit 900MHz (950MHz for the X2)?
Please look again what i said in my previous reply (where I explain why I find difficult for new model like 5870 to hit 900/950MHz in the standard configuration):
So their scenario will have higher die area than mine.
I said that the die will be too big in order to hit for the standard model 900MHz (and 950MHz for the X2) not too big in a general sense.
I also said that, for my scenario, which the die is a little bit smaller.
The reason I predicted that way was, because I think that for some of the games of 2010 the 16 ROPs will be a problem at 1920X1200 unless they hit 900-1GHz at the standard model(which is not that likely in my opinion, since this will be a new design so it would be more difficult to be achieved in relation with 4890, also the 1GHz 4890 is the highest overclocked option)
I just wanted to clarify that, I completely agree with you!
We are talking about what ATI is planning to do.
Nvidia's plan was to launch the GT280 (576mm2 at 65nm) at 650$
But then 4870 (256mm2 or 260mm2 at 55nm) came and they forced Nvidia to revise the price at 450$ in a few days time!
What is the reason that will force ATI to design a GPU with an increase of the die beyond the 315mm2 since they are targeting 300$?
Sure GT200 is a big chip but i don't think companies make plans with this kind of profit per die size.
The competition sometimes forces them to revise their prices but it was not on their original intentions i think.
Theoreticaly the 40nm can bring a clock increase but when ATI launched the RV790 they already used the 55nm for more than a year and the design was essentially the same with RV770 so they could focus only on how they can improve the clock speed.
Also look at the problems TSMC & ATI have with 40nm tech.
The yields are not that good and the 4770 cannot scale its clock speed in a way that it indicate that 40nm will bring a high increase in core speed!
Also what the site proposing is for the standard configuration model,
so essentially they proposing a 50-100MHz clock increase in relation with the standard 4890 configuration (850MHz)!
The only way they can hit 900/950MHz is to use decoupling capacitors like they did with RV790 but this will bring another 9-10% die increase.
So the site essentially proposing 350mm2 die area.
I don't think ATI intention is to sell at 300$ a chip with 350mm2 die area!
Look for example 4870 (256mm2 at 300$) & 3870 (192mm2 at 240$)
So I think with the price strategy that ATI had the last 2 years the site's scenario is a little bit off!
But we agree!
I already read your post. you don't need to keep going back at it. You implied 300mm chip is big. I consider that average to little bit above average. Considering the mainstream GPU's are of that size.
The italics text above was what you said in your reply, about the 5870 specs that the site suggests! My previous reply had focus to show that I said "big" in a sense: that will be difficult for ATI to hit 900Mhz on the standard configuration (like the site suggest) : 1.Since their proposed die is a little bit larger than my scenario's die and 2. In my scenario i find it difficult for ATI to hit 900MHz, why in their scenario the 5870 can hit 900MHz (950MHz for the X2)?
Why would it be difficult to hit 900mhz? 4890 could have easily came off as a 900mhz chip or even beyond considering many chips overclock like crazy. Sometimes hitting beyond 1ghz. 50 more mhz is not magic. It's quite feasible.
I don't understand why you have to repeat things 3x when we both already agreed. No need to acknowledge it 3rd time.
Dude you are speculating upon more speculations. On top of it all you are speculating more that goes beyond the topic. it's like going in circles you trying to explain shit.
Originally posted by: OCguy
In the CPU forum, Aigomorla gets CPUs well before the NDA is up. We need someone like that here for the GPUs. 😛
But he doesn't say anything until NDA is up anyway... 🙂
I cede your point.
Well, Rollo did get information about GPUs before they were released, and I'm pretty sure he had them in his possession as well. IMO they should bring him back on here. Perhaps the third time is the charm. 😀
Ummmmm....
No.
No, no, no, no, no.
Ummmmm....
No.
No, no, no, no, no.
The problem is that Keysplayr tends to respect the NDAs more than Rollo did, and I'm not sure that he has the level of hardware access that Rollo does. He also tends to be far more reserved.
I've come to appreciate Rollo more over at another forum that is not moderated. He's actually quite well spoken with some good ideas (and some wacky ones).
Rollo has his good and bad moments, but I don't really think it's worth the propaganda. I remember when he was telling people to get Geforce FX cards when they said they wanted recommendations on a card to play Half Life 2 and benchmarks were out. It's just silly.
Dude I don't like your attitude at all, being a Diamond Member!
The effect of time participating in the forums these 2 years, did nothing to you, regarding your attidute!
Yes you already read my post but you can't understand it!
Maybe my english is not that good!
I already showed you where I wrote, in my previous replies:
That i don't consider 300mm big in a general sense.
You keep repeting that you consider it a little bit above average and you asked me:
So what you did essentially is characterize the 300mm2 die size in a general sense, since your method was to compare the 300mm die with other GPUs solutions like GT200 in order to conclude that it is average.
So you were wrong implying that i meant big in a general sense!
Please don't lie saying that you meant "average in order to have the ability to hit the 900/950MHz!"
Can't you understand that your question regarding the GT200 doesn't help you at all in your point that you were trying to make?
Of cource you were not meant "GT200 models" like GT250 (G92b), since this is way below 300-315mm2
(my estimation is 251-267mm2 and sites as hardforum report 231mm2)
Also the GT250 can hit up to 800MHz and what the site is proposing is that the 5870 can hit 1GHz (since the standard configurations are 900-950MHz)
So you meant GT280/GT285 (GT200)
In what way a 600/650MHz GPU is helping your case that the 5870 can hit 900/950MHz?
So even if you meant that,
you are wrong again!
Also for ATI history the biggest chip that they ever made if you exclude the 2900XT fiasco was bellow 315mm2!
The only exception is 1900XTX at 351mm2 that was launched at 550$, not exactly the case we are talking!
And it happend only once, in ATI's history at 550$!
So the 300-315mm2 for ATI is quite big,
especially if you consider the 300$ price tag!
Again with the attitude!!!
Out of respect for the author of the topic I will not try to explain to you again!
Already our disagreement goes beyond the topic's intention!
you guys are confusing me on all the pricing talk.
can anyone clear this up and give me a guess as to how ATI will price these at launch?
5850-249
5870-400
5870x2-599
Blah blah blah. Can't you just discuss without trying to get into a personal confrontation?
But you said according to these specs the chip will be big and now you say it's not big? 😕
Considering a mainstream GPU like 8800gt is 334mm. yeah I consider 300mm an average to above average die size coming from a new technology in this day and age.
I'm asking you a question you go around the bush to answer. Stop with your rhetoric.
now you are calling me a liar? Oh god. what did I lie about?
What are you trying to say? Average to hit 900mhz/950mhz? WTF????
I've explained to you why it's not going to be that much bigger than RV770 according to these specs but you say it's big and now it's not big. Can't you say something without using strawman or rhetoric?
Didn't you say something about it's not about who is right or wrong? god you are awful. You say 1 thing and say another. You did this twice in this post alone.
What is your point exactly?
The only exception is 1900XTX at 351mm2 that was launched at 550$, not exactly the case we are talking! And it happend only once, in ATI's history at 550$!
So the 300-315mm2 for ATI is quite big, especially if you consider the 300$ price tag!
What does that have anything to do with what I asked you? Again going in circles without really answering a single thing and then start another subject about die size and price. That my friend is strawman.
To rebuttal your strawman. How about 576mm for $300? That's how much nvidia sold GTX260 for when ATI released RV770. This $300 price tag is not set in stone either so your argument about price and die size is irrelevant.
Again with the attitude!!! Out of respect for the author of the topic I will not try to explain to you again! Already our disagreement goes beyond the topic's intention!
Your entire post is nothing more than rhetoric and strawman. It's pointless you going on and on about something that's not even at topic. I asked you a simple question which you changed it around and said you don't think it's big after you quoted the chip was big.
Azn, Model3. You didn't ask for any advice, but I'd just like to offer that you guys should just reply to each other in single sentences each. Too much info hopping around in the novel posts. Just saying. 🙂
Now, the die size. Does it really matter? He said, they said she said we said.
So the die will be bigger. so what. There is more in it. Bound to happen.
I didn't started anything!
You started the personal confrontation insulting me like this:
I showed you 100 times already the part of the text in my first reply to you,
that I said big only, regarding its ability to hit 900-950MHz.
Also with their specs the die will be very big, I am not sure that they can hit 900MHz in the standard configuration!
Nvidia and ATI (like all the companies) have a limit in die size area, which if they go beyond that limit,
the chances to hit very high clock speeds are getting smaller and smaller! (We are talking same architecture)
Just for example, if the GT280 instead of 576mm2 was 460mm2 (-20%)
the chances would be higher for this 460mm2 chip to hit more than 600MHz (GT280)
We are talking about chances (statistic)!
This is a fact!
The 8800GT 512MB model launched in Q4 2007 at 250$ at 334mm2 and it was not the high end model of the G92.
We are talking about the high end model of the RV870 (or whatever is its name)
And this fact, has nothing to do with ATI die sizes,
which are traditionally way small for this (250-300$) price range than Nvidia's, the last 2 years!
Let's take your example,
the G92 (8800GT) launch at 250$ in Q4 2007:
Nvidia was targeting this price range with a cut down G92 model (334mm2)
But ATI had at 240$ the 3870 at (192mm2) which is way smaller!
No you have not explained anything, you just said the following:
At that time, of course!
But since then, you started to insult me with no reason:
The point is that ATI had in past problems designing chips bigger than 315mm2!
And When their size was around that figure the price was 500-400$!
So unless your speculation is that the site's proposed 5870 will be 500-400$,
then you are wrong acording to the historical data of ATI's pricing policy!
The GT260 launched at 400$ and the GT280 launched at 650$.
So you have to calculate the weighted average for the selling price of GT200 series / per quantity / per model!
So it was not 300$ at all!
In fact it was more close to 500$
Dear god this is like Scali vs Modelworks pt. 2...only worse.
I haven't seen Chizow post in a while so Azn needed a new target. 😛 I did enjoy reading their posts going back and forth over ROP's vs. memory bandwidth vs. shaders. 🙂
How is that personal? I just spitted how I see it. you layered down 10 different subjects and going back in history trying to explain shit when no explanation was needed. However you directly insulted my personal trait.
I showed you 100 times already the part of the text in my first reply to you, that I said big only, regarding its ability to hit 900-950MHz.
What does that have anything to do with the chip being big or not? Do you have comprehension problems?
Nvidia and ATI (like all the companies) have a limit in die size area, which if they go beyond that limit, the chances to hit very high clock speeds are getting smaller and smaller! (We are talking same architecture) Just for example, if the GT280 instead of 576mm2 was 460mm2 (-20%) the chances would be higher for this 460mm2 chip to hit more than 600MHz (GT280) We are talking about chances (statistic)! This is a fact!
What? What is this? More rhetoric? For crying out loud. Can you not say a thing without playing with words and changing the subject?
To answer your fact from fiction. RV770 was 260mm and RV790 is 290mm. While RV790 is bigger and has more transistors it's able to clock much higher than RV770. So what is your point? You compared a entire different architecture and a chip 2x as big to say you can't clock higher if the die size is bigger when it clearly does not.
So you agree a 8800gt that has the 334mm die size sold for less than $300 and still making good profit. Here you are trying to justify yourself by differentiating high end or lower end when the die size is the cost of the chip and whatever left is profit.
Oh really? Here's my quote from my previous post.
No the die will not be big. It's actually quite acceptable considering it will be on 40nm. SP takes up most space in a die and according to these specs it's only 1200SP from 800SP. However those extra TMU will take up some space. It might be a tad bigger than 4870 but not too much.
Looks like I explained it why the chip isn't going to be BIG!
So you are admitting you have a problem? You say things without actually mean what you say? Why do you even say things at all? it's pointless!
What problems? Milking the consumer is a problem? ROFL! You make it seem like your point of view are fact when it clearly is not. It's an opinion which you debunked yourself even in your own reply. 8800gt with 334mm die size was selling for less than $300 like you said. After all both Nvidia and ATI manufacture these chips from TSMC.
Launched for how long? 2weeks? That's when 4870 and Nvidia matched their price by cutting GTX 260 and GTX280 price by $100. Even for those who bought it at launch price people got refunds.
I hope not. I try to keep it simple as possible. 1 point at a time. Model guy however talking about something and more something of continuation to entire GPU history. 😛 I think he's a preacher. Hallauya!
I'm not even going to bother replying you again!
Because for all those "points" that you have in your latest reply, I have answered analytically already!
It is pretty clear that we cannot find a common ground, so let's just say that, we agree to disagree!
Anyone who is reading this topic, can see the points each of us made, so he can make his own conclusions!
Everyone here aren't dumb. At least the forum frequents who's been around. you don't have to repeat entire history of GPU. There was no point. You just changed the subject and created more subjects for you to make a point of something we weren't even discussing. On top it all off you debunked your own supposedly branched out points.
I asked you simple question why you think the chip is big but what I got is rhetoric and strawman. Then say the chip isn't big. It's pointless. You say things without meaning what you say.
NV increased the TU from G80 to G92 while still maintaining the same 128sp's. I don't see why ATI couldn't do the same. I'll be very surprised if we see R8xx debut with only 1200 shaders. But then again, doubling the ROP's and TU's and adding 50% more shaders will significantly increase transistor space/die size. 1200 may be as high as they dare to go if they wish to maintain their "small die" initiative.
Will require some cleverness to fit lots of transistors within a particular manufacturing process, like they did with the HD 4870 compared to the HD 3870, 2.5 times of everything excluding ROP, and only 33% more transistors and die size.
Is your effort to put words in my mouth, ever going to stop?
This is your practise from the start!
It is clear to anyone, that i said that i have faith that the people who are reading this topic,
can understand perfectly, so they will make their own conclusions!
Stop changing the meaning of what i say.
You are arguing about things that nobody implied!
Can't you understand that everybody knows your practice by now?
Whenever I said something logical you replied with like:
What 1+1=2?
What? What is this? More rhetoric? For crying out loud!
I don't even know where to start:
Let's take your scenario that the site's 5870 is 300mm2 (I said 350mm2 with decoupling transistors)
You said that:
if NV can launch 8800GT and make a profit with the 8800GT (334mm2) at 250$
why can't a 5870 (300mm2) have 300$ price at launch?
You comparing the launch price of a 8800GT model,
with what launch price should have a 5870 model, in order to make your points!
For the G92 chip (334mm2) we had also the following higher models (9800GTX, 9800GTS)
So we had:
9800GTX (the highest G92 model with Two 6-pin power connectors)
8800GTS (a lower clock G92 model within the 150W power range)
8800GT (a even lower clock model with some TU&SP disabled)
What you should have done, is to compare the price of 8800GT,
with the price of the analogue ATI model which is the 5830!
For the RV770 (256mm2) we had:
HD4870 (the highest RV770 model with Two 6-pin power connectors)
HD4850 (a lower clock RV770 model within the 150W power range)
HD4830 (a even lower clock model with some TU&SP disabled)
Let's make the analogue product line for the RV870 (or whatever is its real name)
HD5870 (the highest RV870 model with Two 6-pin power connectors)
HD5850 (a lower clock RV870 model within the 150W power range)
HD5830 (a even lower clock model with some TU&SP disabled)
Can you tell me, if you can comprehend now that the parallel model for 8800GT is not the 5870, but the 5830?
Or it difficult for you to understand this also!
Now let's see the launch pricing:
HD4870 300$
HD4850 200$
HD4830 160-150$ (actually it was 130-120$ but it launched later than 4870/4850)
Lets see the analogue launch pricing for the 5800 series:
I will take my scenario, which I said that the die of the site's 5870 would be something like 350mm2,
and according with the pricing history of ATI's should be priced 400$ and lets scale the prices:
HD5870 400$
HD5850 270$
HD5830 210-200$
Even with my high priced scenario, the 5830 is around 50$ less than the launch price of 8800GT(250$)
So for the example you gave (8800GT),
ATI's profit per die size is cheaper than NV's
If I take your scenario that the die is 300mm2 and that the launch price of the 5870 can be achieved at 300$:
HD5870 300$
HD5850 200$
HD5830 160-150$
So with your scenario, you can see clearly, that the 5830 is around 100$ less than the launch price of 8800GT(250$)
So again, for the example you gave (8800GT),
ATI's profit per die size is extremely cheaper than NV's!
Even if i take a completely unrealistic scaling like the below:
HD5870 300$
HD5850 250$
HD5830 200$
it doesn't change the fact, that the 5830 is around 50$ less than the launch price of 8800GT(250$)
And again, for the example you gave (8800GT),
even with this completely unrealistic scaling,
ATI's profit per die size is cheaper than NV's!
So from the start you where trying to suggest:
why can't the 5870 be in the price level or a bit higher than the launch price of a 8800GT?
And I proved you, that with a 300$ 5870 launch price,
the equivalent product (5830) is way cheaper than 8800GT!
Even for my own scenario (350mm2),
I proved you, that even with a 400$ 5870 launch price,
the equivalent product (5830) is cheaper than 8800GT!
And you think that, I have comprehension problems?
Do i have to go to this length, for every point you made, to prove that your points are not valid?
You don't even seem to understand that the profit of the G92 based cards,
is not the profit of the 8800GT model,
but it is the weighted average of the profits of:
9800GTX/8800GTS/8800GT&8800GS models!
Also, have you checked the Financial state of Nvidia lately?
In your last reply, you said the above!
I will repeat the question I asked you in my early, early replies:
Nvidia lowered the original launch prices of GT200, because of 4870 (like you said above),
so essentially Nvidia had lower profit per die size with these new prices!
What is the reason now, that forces ATI, to design a GPU
with lower profit per die size in relation,
with the profit that they had in the past 2 years?
Also if the rumours are true,
isn't going ATI to have the first DX11 solution in the market?
Why they need to lower their margin, when they can make more money based on this fact!
Don't get me wrong it would be nice, for ATI to lower their margin even more!
But this is not about, what i or you want.
We are talking about what ATI wants to do!
Can't you understand that everybody knows your practise by now?
What 1+1=2?
My practice? You accuse me of putting words in your mouth? Before that you called me a liar. If you are accusing me of something at least describe it. Without factual information I can't stop putting words in your mouth or what I lied to you about. All you've been doing is constantly changing the subject without answering a single thing. When it was your turn to answer you've changed your view however you deem fit.
First you said the chip is going to be very big but now it isn't? That's all that I asked. I didn't ask what you thought about what die size and price has to be nor did I ask you why you thought RV870? won't hit 900mhz. You are just putting whole lot of information out there without saying much. That's what you call a strawman. You change the subject without answering the original question that I asked you. Either it's big or not. Not both whatever is convenient for you. For instance when you said something about it's not about who is right or wrong? But then you say it is about who is right or wrong. It's quite silly even speaking to you because you don't mean a damn thing. It's okay when you are BS with your friends but not in general.
There's really no point even replying to rest of your post. Because it's silly and what's this about you being logical? No the logical thing would be to describe why you thought the chip would be big. Not spit out bunch of techno jargon without any proof.
