twinrider1
- Sep 28, 2003
- 4,096
- 64
- 91
They can. Technically you shouldn't be planting over the easement. They generally don't care and will likely restore it as it was before.
Did the OP leave out any details?
Like how he has been calling AT&T 3 times a day for the past month because his DSL was only getting 5.9 Mbps instead of the 6 Mbps he's paying for?
Wouldn't any utility easement tend to be located at or near the perimeter of the property line? If their buried cable is not at the perimeter of the property, then maybe it needs to be re-located.It looks like they have a cable that runs through the entire length of my yard.
You could well be the biggest a**hole I have ever encounterd on any forum anywhere.
As long as you know exactly where the easement is located, then you'd know not to plant a tree near there, that has roots that could eventually reach the buried cable. Or otherwise interfere with a utility's occasional need for backhoe access, such as with a fence or planting bed.
I came home from work yesterday to find a note on my door from AT&T saying that they had to do some maintenance in my backyard. There is currently a 20ft x 4ft hole in my backyard that goes down about 4 feet. They exposed some cables that I guess they're working on.
They dug up two small trees and a bunch of shrubs. These appear to have been removed from the property. They destroyed the border around my planting bed. They also took apart my fence in order to gain access because I had a locked gate. The gate is currently lying broken on my side lawn.
I haven't been able to get a hold of anybody from AT&T yet, but I'm fairly angry. I'm quite appalled that they can just break into my fenced in yard and dig half of it up, destroying the landscaping in the process.
Anybody else have this sort of experience?
I don't even use AT&T service, although my house is wired for it. Apparently my neighbors' lines run through my backyard, which is why they were servicing them.
Everywhere I've lived before had an alley behind every house where cables were run. They only cable that would be in the yard would be a short run from the alley to the house. The neighborhood I live in now doesn't have alleys, so all the cables run through people's yards.
while its established they can do this, seems pretty shitty to not at least let you know first
The cables seem to run the entire length of the yard about 4 feet from the back fence. The house was already landscaped when I moved in.
Well he was at work, so...
pretty sure its been planned, they could have sent him a letter
