[AT] Intel trying to release 7 nm in 2021
moinmoin
5,248
8,463
Density wise, it should be closer to TSMC's 3 nm than 5 nm... but that's just a projection.
Considering Intel effectively has a LP and a HP node as well with the density of the HP version decreasing as they up the room for frequency increases especially on high end desktop (which 99% of the board focus on) I'm not sure the (lowest possible) density of a node as is tells us much at all. Will Intel's 7nm be able to rival TSMC's contemporary node (whatever that will be) in power efficiency, core count and upper limit of operating frequency reachable? Maybe it will, maybe it won't. Taking the experience with Intel's 10nm into consideration managing all that at once will be a hard job for Intel.
Reactions: dmens
jpiniero
17,141
7,527
maddie
5,203
5,612
dmens
2,275
965
Reactions: scannall
jpiniero
17,141
7,527
What is the actual Mtr/mm2 of skl and ryzen1 ?
No actual numbers but the Pinacle Ridge die is denser than Skylake Client die. But of course you are measuring different things, and Intel gives up a lot of density for that mhz.
moinmoin
5,248
8,463
Which is exactly why comparing Intel's 7nm density with TMSC's 5nm or 3nm is meaningless for the products we mostly talk about in this subboard, consumer CPUs.
