ASUS GTX 570 DCII - Great card but odd whining / noise while in DX11
GprophetB
2,632
Hey there everyone, I've been really really pleased so far with both the performance and low noise level from my new shiny ASUS GTX 570
However during any sort of DX11 the card lets out a medium pitched "whine". As SOON as i alt tab back into windows the noise stops.
Not sure if it needs time to "break in" or what.
This is at stock speeds and stock voltage. However i was able to play crysis 2 stable at 800 / 2000 at .985v
EDIT: Computer details
ASUS P8P67 Pro
i7 2600k @ 4.4ghz
8 gb of DDR 3 1600 Corsair
GTX 570 DCII
1 HDD, 1 Optical
Antec TruPower 550 watt
12,333
612
Install FRAPS and I'd bet that it only whines when you're getting like 2000fps.
Nvm looks like it's happening all the time. Sounds like you got a whiny card.
May 13, 2009
12,333
612
You bought the direct cu to run at stock voltage at 800 core?:confused:
Put some voltage and get that core speed up to 900ish.
AnandThenMan
3,991
627
I've installed cards with non reference coolers and left them at stock, I just wanted the additional cooling to ensure reliability no matter what. But the high frequency noise is the result of the regulator sections switching harmonics, which can be very annoying.
BTW, that card is absolutely huge, fair warning to people considering it.
Arkadrel
3,681
Do you mean the "fan"s are makeing a whiny noise?
or...
Do you mean a ceramic capacitor was "singing"?
GprophetB
2,632
I've had only a few days with the card, i plan on going higher but i would like to stay at <1 volt.
GprophetB
2,632
Sometimes its your psu that is whining. Sometimes the video card. You have noticed it happens under load.
What psu do you have , how old is it ?
Rest of computer information.
Are you using a powerstrip or extension cord ?
http://www.youtube.com/watch?v=C4d23F2jehQ
http://www.youtube.com/watch?v=dj1T7JpORA0
It's not under load, its when i flip into DX11 (or tab back into a game) . Alt tab back to windows, it stops immediately. Tab back, whine. etc.
I have a 3 month old Antec 550 trupower
i7 2600k @ stock speeds
8 gig DDR3 1600 corsair
1 Sata hdd
1 optical
GprophetB
2,632
or...
Hmmmm, I'm fairly sure it is not a fan noise. Also im 99% sure its the GTX 570 because i just had an XFX 5770 in the same machine and it did not occur.
Arkadrel
3,681
So a its a capasitor noise... Man I hate those, usually really high pitched.
My dad has bad hearing, he probably wouldnt mind too much. But I notice even the "fluorescent light bulbs"? I believe their called, they often whine and its madning.
notty22
3,375
Did you hook both the 6 pin and 8 pin power connectors up ?
Its a redundant question, but people have done strange things.
GprophetB
2,632
both 6 and the 8 pin connectors are securely installed, as well is the LEDs lit up on the card by the power connectors.
GprophetB
2,632
Ugh, its been 2 weeks and the noise is so annoying, anyone else having the problem?
I want to RMA but i don't want to be video cardless and stuck waiting.
damnit
bryanW1995
11,144
32
Have you forced vsync through ntune? I get that annoying super high pitched whine in the start menu of nwn2 unless I have vsync turned on (results from 3000 fps).
alcoholbob
6,390
470
Try vsync.
Every video card I've owned since the 8800GTS has been a whine-fest without vsync on. With it off the capacitors overload because the fps is in the 100s.
Cookie Monster
5,161
32
86
Capacitors can NOT whine (physically impossible). But they can be the cause of the whining, and this whining is coming from the inductor squealing. Its normal and you shouldn't worry about it.
However it can get very annoying so try different settings like the use of vsnyc like the others suggested.
GprophetB
2,632
Well turning Vsync on did significantly reduce the whine, however there is still some there. I guess since my new computer is so quiet even the slightest buzz or whine is noticeable. I would say turning vsync on reduced whine by about 80&#37; ... so now its more than tolerable.
Still sorta odd though especially for such a nice GPU. Thanks guys.
GprophetB
2,632
Not sure if im just getting used to it or if it's decreasing. Will keep posted. I was considering buying another one of these to SLI as well.
raad11
16
I'm getting a similar type of whining noise as the fan spins up in games. I've only tried StarCraft II so far.
This is completely harmless, right? My case's cover is off right now so when I close it up I can barely hear it, so noise isn't an issue for me. I was just concerned the noise might indicate some kind of problem or fault...
Btw does anyone get crashes when overclocking this in the new Deus Ex game?
BathroomFeeling
210
Sounds like little bells ringing. I remember my old system used to have this noise, turned out to be a loose molex connector hitting the spinning CPU fan.
Feb 19, 2009
10,457
10
I had this problem on my old 4870, it came from the PCB components of the card itself (after troubleshooting for ages), under high load it has a very annoying bbnnnzzzz noise. Its not loud, its the pitch that is irritating.
