Ejhocky313
- Sep 20, 2005
- 42
- 0
- 0
Anyone with the 939Dual-SATA2 board fully go over to Windows Vista? Have any errors with the SATA2 driver or the onboard NIC? In was thinking of upgrading to Vista but I don't want to have errors.
Originally posted by: coloumb
Interesing board...
However, forum posts from other sites indicate that ATI Vista/Dual Core AMD cpu's are still an issue [can't get it to work unless you disable the dual-cpu option]?
Interesing board...
Not sure what you're referring to there. I'm running a Radeon 9700 Pro in Vista with no problems right now, and had an Opteron 170 (and an X1900XT) for a while last year that also ran Vista RC2 with no problems.
Could you elaborate on what kind of issues others are seeing?
Originally posted by: crockman
Questions of Compatibility & Drivers please.
I bought this 939Dual-Sata2 MB from Newegg a couple months ago, but havent used it yet. Now that Vista is out I might as well get Vista to use with this MB, being i need an OS anyway.
I'd like to get the Vista Home Premium 64-bit Version.
My MB has BIOS Version P 1.90-8B
The Parts to be used on this MB are:
Vista Home Premium 64-Bit (That is if 64-bit is compatible)
AMD 64 3700+
WD Raptor 36 Gig 16MB Cache Sata1 (Plan to RAID 2 of these at a Future time)
Nvidia 6800 Vanilla AGP (Plan to use a PCI-e in the future)
Audigy-Value Sound card
A-Data Vitesta DDR400 Dual Channel 2 x 1Gb
I'm guessing that I'll have no problems running the above mentioned Parts on this MB, Opinions Please.
Main Question is of the Compatibility of the 64-Bit Version of Vista, Opinions Please. & secondly is my A-Data Ram acceptable ?
Thanks
I personally ran the 64-bit version of RC2 (Ultimate) for over a month on my board with no issues (currently using 32-bit RTM, halfway thinking about switching back to 64 at some point). I used a PCI-E X1900XT and an Audigy 2 at the time. While I can't tell you with 100% certainty that everything will work since I haven't really used the 64-bit RTM version, based on my past and present experiences with Vista on this board I would say it's extremely unlikely that you'll run into compatibility problems. (I can't really speak for Nvidia's drivers though since I haven't used one of their cards since last summer.)
Originally posted by: WT
Not much from that above link, considering we are at 42 pages of this thread and there were a few users posting issues with certain AGP cards in that thread. You pick any board available today and I'll link you a few users groaning about how it doesn't work with their hardware. One thing I seem to recall is this board not liking some versions of 9600 cards, so unless you have an old ATI card you plan on using, stop worrying and find one when you can before they are completely gone. If mine ever dies, I'm framing it and hanging it on the wall above my workbench.
Originally posted by: DarkManX4lf
ok I'm using this board with Vista Ultimate and at stock cpu/ram settings vista randomly freezes on me, my ram checks out to be fine in memtest...does this happen to anyone else?
Originally posted by: Woody
Have you guys seen the prices of Opteron 165 and 170 chips this week?
Around $160-$190
I'm thinking about dropping one in there to replace my single core 3700 which never overclocked well anyway.
Any thoughts on if the 10x multiplier is worth an extra $30 over the 9x? My guess is it's a toss up on which chip will reach the fastest core speed. What is typical for these chips? I hear about 2700-2800MHz max with extra cooling and 1.45V (haven't done a voltage mod).
As I write this on my laptop I'm running tests on my board (1.80) to see how far I can get the bus speed with the CPU at a reduced multiplier and RAM set to 166. I'm running Prime95 at 260MHz now but I'm sure I can go farther. I'm going to set the HTT multipliers back to 3X (600MHz) before proceeding past 260MHz.
The only random freezes I get are when running OpenGL apps with AA on; I've been operating under the assumption that it's just ATI's drivers since I can't recall freezes or hard locks in any other situation since I've been using Vista Ultimate RTM.
Actually, I see in your sig that you have a Radeon 9800 (I'm using a 9700 Pro right now)...wonder if it is related to ATI. By random freezes, do you mean that you haven't been able to determine a pattern?
