Hi all,
i got this motherboard in september 2006
i have some question for you all 939Dual-SATA2 owners:
-does your sound (from the integrated chip) work ok? i usually listen on my headphones ( a pair of cheap TEAC HP-2 and another PHILIPS SHP2500 ) and when setting the volume at 100% (Windows or Linux) the sound gets distorted (like it just hit the hardware limit of the chip or the headphones), but the sound is not loud enough.
compared to my old motheboard ( ASUS A7N266-VM SE / nForce 220D / SoundStorm powered by a Realtek 650 chip ) the 939Dual@100% volume sounds (is loud) like the ASUSboard@75% volume.
at first i thought the headphones could not handle it but on the ASUS board they sound ok even at 100% (not to mention that it just feels like my ears are going to bleed
). any ideas before i get some Audigy SE?
-about OC, i'm just experimenting some stuff, with the stock cooling on my Venice 3500+ 2200MHz (200x11), and so far the max clack was 2530 (230x11), limited only by stability tests with SuperPI (XS), i would lower my clock until Superpi would not get "SQARE ROOT IS NOT CONVERGENT" errors. my setup consists in setting the HTT@800Mhz and DDR@166MHz, the temperatures are always ok, so why do i get the errors at 230MHz?
-afaik the Venice has the multiplier locked (as opposed to the Opterons), but i tried setting my multiplier to 10x, set the bus at 240, rebooted, entered the BIOS and it said 2400MHz, so i rebooted in Windows where the clock was 240x11=2640MHz, why ?
10x
