VooDooAddict
- Jun 4, 2004
- 1,057
- 0
- 0
Originally posted by: Treyshadow
It would be a toss up between the Jetway A210GDMS-ro or the Foxconn NF4K8MC-RS
Both have seen some good reviews. Also check on the as there is lots of discussioni on that Jetway. I know its a Jetway, but I think I am going to pull the trigger and try it out.
Originally posted by: JobLessOne
yeah ive had the case for a month now, and I love it. Yeah I would never use the handle to carry it around, but the case is so small you can hold it without any problems. As for the power supply, to me its really quiet, because it doesn?t blow that much air from it, the 120mm fan is the one that does all the work.
also bneta86, that heatsink fan should fit, as I used this coolermaster fan, and it fit barely, after I removed the top fan guard.
Coolermaster cpu fan
and yes the seasonic S12 should fit with no problem
bneta86, if you are looking for a socket A matx, check out this motherboard, its really good.
http://www.msicomputer.com/product/p_spec.asp?model=K7N2GM2-LSR&class=mb
robstv, did newegg replace the motherboard for you? if not, you can RMA it thru MSI even though its refurbed.
