Ars Rips on intel with KL review
NTMBK
10,519
6,029
Weird in those threads with the denial of the HT pointlessness. People started saying its important on i3s...but don't i3s have extra cache and clockspeed over pentium dual cores making it the same Apples to Oranges comparison?
Speaking from experience, I've written very memory bandwidth intensive, highly multithreaded code which benefits a great deal from Hyperthreading. Run on the exact same CPU (apart from HT being enabled/disabled), I've seen it add ~15% performance.
Depends on the use case, but if your code is often stalling on fetches from main memory you will probably see improvements.
TheELF
4,029
753
Disable HT on an i3 and compare some well threaded games...
(or just use affinity to restrict the game to two cores)
you will get double the FPS with HT working,cache and clockspeeds are just the gravy.
inf64
3,884
4,692
Sorry to tell this to you, but nobody sane will buy dual core SMT enabled chip in 2017 for gaming on a budget build. Not with quoted i3/pentium KL prices when something way better is coming for a bit more $$ :). 8 threads for a slight bump in price, unlocked, high IPC core. No comparison, they will lose it in this segment (also :D)
Reactions: Drazick
PingSpike
21,765
615
That's kind of what I expect out of it, on certain specific types of workloads it makes a noticeable but somewhat marginal difference. But its always been put as a big selling point feature in the Intel lineup that I never thought should really command a premium. And because its paired with cache or clockspeed boosts this myth has grown up that its the HT that is actually making the difference. If those gaming tests are to be believed, its actually a double edged sword that sometimes harms performance just by being enabled.
LTC8K6
28,520
1,576
Just a bit more than the $64 cost of a KL Pentium?
inf64
3,884
4,692
~100 or so bucks for nearly 2x more performance in CPU intensive workloads? I would go for it, wouldn't you?
BTW is that KL Pentium unlocked? If you cannot OC it then 3.5Ghz is worthless for gaming on a budget since you don't get 4 real cores like in an i5.
Reactions: Drazick
lolfail9001
1,056
353
So, you have AMD's price list already? Care to share? Telling you last time: if Zen performs as matching i7, it will be priced in the area of matching i7, not significantly below.
Yeah, except it is 70 bucks, good luck beating it for value.
LTC8K6
28,520
1,576
You already know you can get an unlocked RyZen chip for ~$100?
And that it will have 2X the performance of what Intel offers in that ballpark? Which would be a 3.9ghz i3.
Reactions: Sweepr
krumme
5,956
1,596
Ok better tell amd because then it looks to me they named their zen sr3 sr5 sr7 wrong ;)
Sweepr
5,148
1,143
For $64 it is a much better alternative than anything AMD got in their APU lineup in terms of CPU perf/$ and upgrading path, and will have no competition till H2-2017 at the earliest. And yes, Core i3-6100 like performance will be more than enough for >99% use cases of budget users running $100-200 dGPUs, as stated by people who actually own 2C/4T Skylake/Kaby Lake, which is not your case.
Again confusing what you wish for what is likely to happen, some people never learn. Not everybody shopping for $60-80 CPUs is willing to spend 2-3x as much, even if that gives them much better performance (be it Intel or AMD).
LTC8K6
28,520
1,576
It wouldn't make any sense to sell an i7 competitor too much below i7 prices, though.
I can't imagine AMD undercutting the i7 that much, especially if the Sr7 chip has more actual cores.
AMD should be selling on performance, not price.
2,012
This CPU is great for a budget general purpose + gaming rig. Put a decent GPU in the system, hook it up to a cheap 1080p monitor, and it'll play anything you want.
Not sure why you are ripping on this CPU so harshly.
inf64
3,884
4,692
Of course it is good for the money , no doubt about it. But dual core in 2017 in a budget build? SMT cannot replace real cores, it can help somewhat. One cannot simply ignore elephant in the room. And another, greater elephant is coming in H2 2017, with great iGPU and likely lower price for same core/thread count.
Rifter
751
We may want to wait untill Zen actually launches before speculating on prices and making comparisons to i3's, i expect there lowest end CPU to be in the $75-150 range but this has yet to be verified.
But the people suggesting a dual core for gaming in 2017 are pretty funny.
Reactions: coercitiv
RichUK
10,341
678
Depends what games you play and the settings / frames you expect. 1080p 60FPS on an i3 is fine.
Reactions: Drazick and Ken g6
TheELF
4,029
753
That's why they are called budged builds,you go for cheap components.
It doesn't have to replace real cores,it only has to replace butchered half breed jaguar CMT cores (that run at ~1,5Ghz)
Also here is a old test of i3 with and without HT running older games that are not as well threaded as todays.
Huge improvement especially for min FPS and that's on a very early implementation of HT in most cases the i3+ht matches the real quad(and even the real quad+ht since most games don't scale much beyond 4 threads)
http://techbuyersguru.com/dual-core-quad-core-and-hyperthreading-benchmark-analysis?page=1
Reactions: Phynaz and Ken g6
inf64
3,884
4,692
Jaguar is not CMT core , just FYI. Just like Zen is not CMT (like you claimed in another thread).
Yes, SMT brings improvements to fps but still it is not a real core replacement. That is why i5 is an order of magnitude better chip for games than i3.
Reactions: Drazick
LTC8K6
28,520
1,576
When? Newegg shows 0 results for "ryzen"
Not that you can get all of these chips now either. But I really do wonder when each of these chips will be available.
What in the world caused you to check Newegg for RyZen?
Ken g6
Moderator
Dec 11, 1999
16,771
4,744
75
What, I should have checked Amazon? :p (Nothing but FX there.)
You were acting like getting a RyZen processor was a viable option now or in the very near future. When will it be a viable option? A Kaby Lake Pentium says it's "launched", but I can't find any in stores either. Does either company even have an official availability date for either product?
The real point is, how long will Kaby Lake Pentiums be available while RyZen is not? I'm guessing 0-6 months.
Reactions: Drazick
2,012
H2'17? I don't know of any desktop APUs that will be superior.
Raven Ridge for desktop is likely 1H 2018 :p
LTC8K6
28,520
1,576
You missed the question marks.
I was asking Info64 questions.
He is the one who apparently knows RyZen performance, pricing, and availability, and the future of 2C/4T processors...
Ken g6
Moderator
Dec 11, 1999
16,771
4,744
75
That I did. :oops: Sorry.
Looking that far back, I also think he meant RyZen would be ~$100 more than this Pentium. But maybe I missed something there too.
Reactions: Drazick
