Corporate Thug
i slept on one for a few months, Not comfortable but tolerable
Originally posted by: SilthDraeth
IMHO
It depends partially on the mattress, but I believe the real culprit is the frame. If the futon in question has round metal bars, it doesn't matter if they have 3" or 6" spaces, every bar makes a pressure point, and are incredibly uncomfortable. If you are buying a decent wood framed futon, with slats, that have about a 1" to 4" spacing between the slats, and it folds out into a nice flat surface without a ridge down the middle of the two pieces, then it can be quite comfortable. You can even take another person's suggestion and use a memory foam mattress topper to add extra comfort.
I would honestly buy a well designed wooden framed futon, but never a metal one.
That looks like a futon I had like 8 years ago. If you are going to be buying that futon offline though, I would call the company, and express your interest in it, and ask if they can provide you with photos of the frame without the mattress, in both "couch" and "bed" positions, so you can make sure. Some wooden framed futons have widely spaced slats.
I would guess though, that the one you linked is well made, by the look of that premium mattress.
