Arctic Cooling
Xvys
202
These are good coolers, especially for the price. But I have destroyed two of these by not having the pin fully in the hole when you click it. It rocks back and forth and is really hard to see the holes unless the mb is removed from the case. So if you want your F7 to last more than two installs, always install it out of the case. The plastic pins on the F7 are of much softer plastic than the stock Intel pins. So they can bend sideways very easily if they are not aligned perfectly in the hole. As good of engineers as the Germans are, I'm sure this was not just an oversight...and they got $40 out of me.
JimiP
258
Originally posted by: emblem
So you didn't have to remove the mobo at all when you installed the AC F7P? Good to hear. I'm getting mine in the mail on Friday. Was it hard to push the pins through?
It's not absolutely necessary but as others have said, it is recommended. Mine went in without trouble but that may not be the case with everyone.
