Nebor wins the troll award for this thread.
yea, most forums i'm on have an ignore feature. why not this one?
so if anyone can tell me how to delete something from the registry that will not allow me to delete it, I will buy you a cookie. I really don't want to reformat.
Would CCleaner do it? It has a registry cleaning/fixing tool.
Also, try deleting it in safe mode.
Well I can't lurk anymore, as for once I have something to add to the conversation.
Any XBox 360 wireless controller will work on the PC, if you also purchase the USB XBox wireless receiver, which can accommodate up to 4 wireless controllers. The "plug and charge connector" you can use on the Xbox to turn your wireless into a wired controller while charging your controller will not work on the PC--it has to be wireless. The PC will recognize the device if you plug it in but it will not work on any games. This is MS at work, making you buy more stuff, as functionally there is no reason for it not to work that way. (Works on the XBox that way...)
Wired XBox controllers will work by simply downloading the drivers and plugging them in.
Figured this out last week after building a new gaming rig for myself. Works great on popular games that are also available on Xbox, e.g. Arkham Asylum, BioShock, even Rage. I play on a TV from the couch so the wireless controller is much more comfortable than the K+M.
One piece of advice: if you have the XBox next to the PC (as I do) it is a good idea to have one controller reserved for the PC and others reserved for the XBox. This is to avoid the hassle of turning on your Xbox every time you want to use the controller on the PC. You pair it with the PC the way you do with the Xbox, i.e. push the small button on the receiver to make the light flash, then push the small button on the top of the controller next to the wired port to make the controller speak to the receiver. Pair it back to the XBox the same way.
And one more thing--if you shut down the PC (and the USB receiver) before the controller turns off, it will run out of batteries constantly searching for the signal! This is the only annoying thing about it. You should remove the battery pack and then pop it back in to turn it off when you're not using it. (Guide button does nothing on PC unless the game has some use for it.)
I'm sorry, I just simply do not believe that an Xbox 360 controller could work for Windows.
Yeah that's what I did too, although I was lazy and went to Best Buy.You can buy the entire wireless PC gamepad kit complete with charger usb wire, reciever and recharchable batteries. I got the black kit and only paid $47.99 shipped
No, the play and charge cord is only for charging, while the control connection is always wireless, both on the 360 and the PC.The "plug and charge connector" you can use on the Xbox to turn your wireless into a wired controller while charging your controller will not work on the PC--it has to be wireless. The PC will recognize the device if you plug it in but it will not work on any games. This is MS at work, making you buy more stuff, as functionally there is no reason for it not to work that way. (Works on the XBox that way...)
I also do not believe that the Xbox controller can work on a PC. It's just not the way I was raised.
Anyone have any links to this? I've been looking on Amazon but can't seem to find a legit one. Would prefer to get it from there too. And do you guys prefer the wired or wireless version?You can buy the entire wireless PC gamepad kit complete with charger usb wire, reciever and recharchable batteries. I got the black kit and only paid $47.99 shipped
Am I the only one that can't stand the 360 controller? I much prefer the PS style. I currently use a PS2 controller on my PC when needed. No feedback, but then I don't really care about that. No it does not work out of the box, you need an adapter and an external mapping program. I know I know, it's not butt easy plug n play, but again, I can't stand the Xbox controller, never have been able to.
Edit: Actually just found this one which seems legit and the seller is Amazon...
I also currently have a wireless one but would need just the receiver, which seems to be hard to come by, at least an authentic one.
I have heard that, I think it is BS. 1) When I would have trouble with the wireless signal, even on a full battery charge, if I plugged it in it would work without interruption; 2) the plug and charge cord sends and receives some sort of data, as it obviously communicates with the PC when it is plugged in since Win 7 does its usual thing and downloads drivers and recognizes the "plug and charge" kit in the device list; 3) if you remove the battery and plug it into the Xbox with the cord, the controller still works, indicating it is sending and receiving information and not just charging batteries. See this thread for the debunking.
MS has purposefully gimped the driver so you need to either buy the wireless receiver or use a wired controller.
