Originally posted by: acemcmac
damn you auto locking doors
block the tailpipe (very well) it should choke itself out.
Originally posted by: Syringer
Ha, it's been 15 hours since the OP posted this..
Originally posted by: middlehead
Originally posted by: KK
Tap your windshield.
I know somebody who could really use that. Might have to be a late christmas present
While you're right about the voltage thing, one time I was using a spark plug tester (Has a high voltage for you to of course test the spark plug) and while it was a very high voltage (Which is required for it to be the resistance of the gap), I tried it on my self, didn't do anything to me. Wasn't a very big deal, obviously cause I'm alive and not "6 feet under". An alternator in a car simply converts low voltage high amps into High voltage low amps, so it shouldn't exactly be much of an issue...Originally posted by: Kalvin00
Originally posted by: GroundZero
ok idiots, if you can get under the hood, yank the coil wire
problem solved, and you'll get a little jolt when you do as an incentive to not be a dumbass and lock your keys in the running car next time
NO! Please, folks, do NOT pull ignition wires off on a modern vehicle while it is running...they are capable of producing 50,000+ volts...many a mechanic is six feet under because they made the mistake of yanking off a plug wire.
DONT DO IT!
Are you serious?
I am quite serious. It is a serious danger, do not attempt this stunt.
Originally posted by: RagingBITCH
Blow up your V6 Mustang, claim arson, and get a real car.
BwhahahahaahahahahahahahahahaOriginally posted by: Kalvin00
DONT DO IT!
Are you serious?
An alternator does not "convert low voltage high amps into high voltage low amps".Originally posted by: goku
DONT DO IT!
Are you serious?
Regarding the fuel consumption, you would actually be surprised.Originally posted by: acemcmac
Update:
Let me tell you what happened so you can stop bumping it. First, I was 3 hours from home where I have my only spare anything- a spare keyfob, which won't work while the engine is running anyway. Spare keys for late model fords have HUGE plastic heads on them for the ignition chips so it's prohibitively large to keep in your wallet. A straight door-only key might have fit though and I will have to look into that.
A locksmith came and got the door release latch on the inside of the passenger side door.
As he was doing that, I was running the fuel consumption numbers, assuming that idling at 600rpm is a ratio less fuel consumption than 2500rmp <- cruising at 85-90 and I figured that the car might have made it til morning when I had a new key cut from the VIN at a ford dealer. Not sure if there would have been any consequences to running the car completley dry except for having to bring it more gas.... mabye I should have done that instead.
Oh well. I fvcked up. I pwn3d myself. $116 and change
/thread
Actually, you're right, I must have confused the two!Originally posted by: Eli
DONT DO IT!
Are you serious?
An alternator turns rotational force into 3-phase alternating current, and then a diode bank rectifies it into DC current to charge your battery.
The ignition coil does what you speak of.
