Anyone have any idea how to stop a running car if you're locked out of it?
Pacfanweb
13,158
59
Originally posted by: conehead433
Originally posted by: Pacfanweb
Originally posted by: GroundZero
ok idiots, if you can get under the hood, yank the coil wire
Already suggested. Read the thread first.
999 out of 1000 people won't be able to get the hood open on any modern vehichle without being able to pull the hood latch from inside the car.
Agreed. That's why I said he needed a lockout service.
GroundZero
3,669
problem solved, and you'll get a little jolt when you do as an incentive to not be a dumbass and lock your keys in the running car next time
NO! Please, folks, do NOT pull ignition wires off on a modern vehicle while it is running...they are capable of producing 50,000+ volts...many a mechanic is six feet under because they made the mistake of yanking off a plug wire.
DONT DO IT!
Not true. There isn't enough amps there to kill anybody.
I've been zapped a few times "hot sparking" the ignition coil. What that means is if you have a flood condition (plugs are fuel soaked), when you you pull the ignition coil and inch or so away from the distributor it makes the coil step up the voltage to cross the gap. Sometimes makes a plug fire that ordinarily wouldn't.
If anything, an old guy that isn't expecting a zap maybe died of a heart attack. But while there's plenty of voltage there, it isn't enough amps. There can be 100,000 volts in a static electricity shock you get off something that just came out of the dryer you know.
just what i said
Pacfanweb
13,158
59
DONT DO IT!
Wrong. It will zap you but won't kill you.
Shawn
32,236
53
Happened to me once since my aftermarket alarm auto locks also. :( Luckly though I just called campus police and they came by with a slimjim and unlocked it for me.
Jun 4, 2005
19,723
Too bad you're not driving a shitbox tempo like my brother used to. He locked his keys in and all I had to do was grab a screwdriver and pop the lock through a hole under the handle.
drnickriviera
2,462
270
Originally posted by: LoKe
Pull the battery out, let the car run out of gas. I'd say that's your only option unless you know how to work with a transmission, or you're willing to learn. Have any tools around?
2. It wouldn't matter anyway, disconnecting the battery wouldn't make the car cut off.
I have a Ram 2500 diesel. Couple of years ago, both batteries died. I could jumpstart the truck and it would run (barely), but the instant I used anything electrical, the engine would die. I couldn't even use the turn signals or the radio. You would think a diesel of all engines would be able to run off the alternator
platinumike
2,114
Get a butter knife jam it between the window gasket and the window. Stick your fingers in between the gap you have created(yes this may hurt a bit) pull the window down as much as you can, now pull it towards you. Stick your arm in there and unlock it with your fingers. Problem solved, and its guranteed to work!
CFster
1,903
No.
Looney
21,938
1. He can't pull the battery out, since he can't get inside to pull the hood release.
Plenty of cars have a button or a lever under the hood so you can pop it up with ease.
It'd prevent your battery from dying if you decide to let the car idle to death.
3. The transmission is irrelevant to cutting the car off, unless you have a manual and you can get inside the car to let the clutch out in a high gear to stall it.
Transmission provides power, I'm no expert, but I think a car without a battery nor a tranny would give out eventually...
Also, you could sift the gas out. ~_~
Wow, you have ABSOLUTELY NO CLUE what you're talking about.
Gunslinger08
13,234
Even if he does get the car stopped, he's still going to need to call someone to unlock the doors... so why take the chance of damaging your car or killing yourself? Just call AAA or a local towing place and have them unlock it.
Pacfanweb
13,158
59
Depends on in what way the batteries failed. If they were shorted internally, that could suck all the power from the alternator and not leave enough for the vehicle to run or at least not for accessories.
True test would have been to jump it off, then disconnect the batteries and see if everything worked okay.
Pacfanweb
13,158
59
Hope you were joking.
Bassyhead
4,545
Seriously, just plug up the exhaust pipe(s) with an old rag. The engine will unable to draw fresh air into the intake and stall. The car will still be locked, and the battery will eventually die without the engine running as the key will be switched to "Run".
CFster
1,903
Used to be the case that a diesel would stay running without a battery or alternator - as the combustion is compression dependant, not spark dependant - that and they had mechanical fuel pumps.
Nowadays, they have electric fuel pumps, and electronic fuel distributors, so they'll die just like a gas job.
Vette73
21,503
9
OK as a autotech there are not to many GOOD ways to stop the car. But here ya go.
1. Crawl under the rear of the car. Look for wires leading to fuel tank. Follow those until you see a wiring harness. Disconnect the wiring harnes. This will kill the power to the fuel pump. Car will run another minute or so, that is normal, and stall.
2. If you can get under the hood pull the coil wire as someone else said. No it will not kill you. I have been shocked MANY times when I had my old Firebird that had a MSD coil and a MSD 6 ignation box and i am still here.
3. if under the hood and you have a car with multi-ignation coils then there is no single wire to pull. So next best thing is to take the air hose of the engine. Most cars have mass air flow meters and when you remove the air hose the car will probable stall. If not take your hand and cover the throttle body. No air, no run.
Those are 3 things that will work and not destroy your car.
Jun 14, 2003
10,442
jus gonna have to let it run out of gas, and call one of those dudes to stick coat hangers down your window sills to open the car
what happened to your SECOND set of keys?
