Kaido
- Feb 14, 2004
- 52,123
- 7,508
- 136
Originally posted by: Drakkon
Originally posted by: teclis1023
The only Apple product that I think is overpriced is the Mac Pro tower. There's no doubt it's an awesome system - well built, etc. etc. The only problem is that the Xeons utilize the same performance specs as the Core processors, so unless you want 8 cores, there's no need to go for Xeons.
If I had my way, Apple would offer two Mac Pro base models:
Mac Pro Quad-Core ~ $1999
Core2Quad Q6700
4GB DDR2-1066
500GB Hard Drive
Of course, it would be upgradeable, including up to the QX6850, 16GB RAM, 4 SATA HDDs, etc.)
Mac Pro Eight-Core ~ $3299
2 x Quad-Core Xeon 5355
4GB FB-DIMM DDR2-667
750GB Hard Drive
Anyways, just my dreams![]()
We just got 3 of the 8 cores here at work and i must say they are impressive (maxed out at 16GB of ram and close to 2TB of HD space - dept had wayyy too much money to spend) but when it comes to apps that can actually use all that power they are woefully inadiquate. We had all 3 running Maya rendering using mental ray a 420 frame movie and it took almost 24 hours. I switched it up and put two 2x3.0 Ghz Xeons running windows instead of the two macs and they did it in 8 hours. Something about the instruction set clearly isnt as up to snuff for some reason.
Nah, it's Maya. Get C4D if you want performance
