In my bedroom, I have my tablet and my lightweight notebook (ASUS Zenbook UX31A) fairly close by. Honestly, I'd rather use the notebook over the tablet in
most cases.
Although, the Zenbook has also been one of my most disliked laptop purchases (story time). It's an ultrabook, which means you already pay more for less capability. However, when I bought it, Newegg threw in a free extended warranty -- a nice touch, right? Wrong. After a couple months, I started having issues with my laptop. My tests indicated that the issues were caused by the storage (SSD) getting too hot after doing too much work and simply failing. For example, the system wouldn't even boot after restoring from a back-up -- it just BSOD'd for hours. If you left it alone, it would work fine for a few hours until it got too hot again.
Unfortunately, I just kind of ignored the problem for a while, and instead of using the ASUS warranty, I had to use the extended warranty from Newegg. After talking to the warranty people, he forwarded me to VT Services. I'm going to be pretty frank and say that VT Services is
terrible and
utterly incompetent. I told them that I was fairly certain that the SSD was the problem, and that it first occurred when I was playing a game (Torchlight II) on the system. The first time that I sent it in, they sent it back stating that they couldn't replicate the problem. Really? That's funny since the Event Log states that it BSOD'd while you had it
Not only that, they shipped the laptop back to me
turned on. If this laptop had a mechanical drive, it would likely be damaged.
At this point, I wanted to just fix the thing myself. Unfortunately, the biggest problem with the UX31A is that it uses a proprietary SSD that you could only source from eBay for a ludicrous amount (around $1.5 to $2 per GB), and other users reported having issues with the same drive. So, why would I want to pay that much for a
used drive that would have the same problem? I decided to send it in again while mentioning my displeasure with their first service, and reiterating what had happened. Well, their grand idea of testing had them browse World Hip Hop News (or whatever it's called) and play Gang Wars on Facebook. As you can guess, nothing came up. At this point, I was frustrated and relegated the laptop to being a busted thing that sort of worked as long as you kept it cool. I actually tried to call the original warranty place that sent me to VT Services, but I sat on hold for
two and a half hours before I gave up.
Awhile later, I ended up finding out that Amazon stocked an adapter that converts ASUS's proprietary SSD connector to M.2. So, I ordered one of those and a normal M.2 drive. The first thing that I noticed while working on it was that VT Services lost one of the screws to the bottom of my laptop, and also managed to destroy the threads on that hole as no other screw will stay secured. Then I opened it up and was even more angry at them as they also managed to ruin the screw holding down the SSD. Even though I had the correct screwdriver to turn it, it was rounded out and wouldn't turn. I ended up
taking a dremel to my laptop to
cut a slot in the ruined screw. Amusingly enough, I found that advice in an old thread on this forum... so thanks.
The best part? It works fine now that I replaced the SSD.
