- Apr 14, 2013
- 125
- 2
- 81
I bought ASUS RT-AC51U, and I cannot connect it, idk whyAccording to the modem manufacturer, the modem is capable of 100Mbps up and 50Mbps down (VDSL2).
As dave_the_nerd mentioned, QoS should help. Now we just need to see if the modem/router combo has QoS capabilities. If it doesn't, then it does support bridge mode, so you can add your own router with QoS capabilities.
Type: PPPoE
Type: Bridge Connection
Modulation Type: ADSL_2plus
I did the quick setup, said it's not connected, then i had to choose con type, I press pppoe and it said I need username nad pw from ISP, I contacted my ISP tcom, nub said "we dont recommend any other hardware than theirs" "if any prob with their hardware to go to ww..." I open 2 forum posts on croatian forums.
I connected my pc to LAN1 of new router, and WAN to WAN from routers.., the router.asus.com recognized the router and it failed at automatic setup
