Any way to split internet connection between 2 pc's that won't affect eachothers ping
AnonymouseUser
9,943
107
that field and couple of others are not there :p, ye i guess I need other router, but it's 40€ gamble if it will help
I would assume that if you purchased a new router for QoS and it failed to fix your issue, you could return the router for a refund. Where would you purchase? If the router choices are listed on the stores website, we could help choose a satisfactory model.
Reactions: akmaggot666
akmaggot666
125
I am now on a BF4 server, I turn on 3 pages with 1080p youtube vids and I put torrent on, and ping goes max 150ms and it doesn't actually teleport me, I have no idea why.. it doesnt lagg that much, or even at all...
and when my roommate watches youtube it puts me even above 300ms, how? and why?
AnonymouseUser
9,943
107
I don't know why the discrepancy. Are you both using wireless connections, and are they both wireless N? Wireless b or g will likely be fine for one user with that much streaming, but a second user will cause lag. Even if one user is using b or g, it will slow the entire wireless network to b or g speeds.
akmaggot666
125
ye both wifi, idk what n b or g is
AnonymouseUser
9,943
107
Change the Mode here to 802.11n only. If one or both of you can no longer connect, then you're both not using wireless n adapters.
** Note that if neither of you can connect via wireless after making this change, you will need to use a network cable to connect to the router and undo this setting. **
akmaggot666
125
will try tomorrow, I ask my bro smthg and he said when others watch yt it laggs for him more than when he does it
akmaggot666
125
ok I actually wont do it cuz I dont have the cable ;D
akmaggot666
125
ok, hovering over internet connection already tells me it's 802.11n, gotta check roommates, even tho I read a bit on internet, idk how that would affect anything since 802.11b uses speed of 11Mb/s
AnonymouseUser
9,943
107
Since it is n you know you won't get locked out, so go ahead and set the Mode to 802.11n only.
sdifox
100,897
18,092
Is there any reason why you cannot test hardwire? Just connect your pc to the wifi router with ethernet cable.
AnonymouseUser
9,943
107
and that would test exactly what?
For one thing, it would verify if the wireless connections are getting the full speed of the internet connection. It's not unusual for modem/router combos to have insufficient wireless hardware, especially since the device shares a CPU between the modem and the router.
Go ahead and get a dedicated router with QoS, set the modem to bridge mode, and see how it performs. There's no guarantee it will completely solve your issue, but you can always return the router if it doesn't help.
akmaggot666
125
when I get the new router, I raplace the old one or I need to bridge it with this one so both are turned on? and if, what cables are needed. And which ones would be ok, .. just wanted to post here link but the website is now down for some odd reason, what are the chances o.o, gona add it later
akmaggot666
125
TL-WN822N is my adapter, it's cheap now but I remember it being like 3 times the price as it's now back then
sdifox
100,897
18,092
Gaming over wifi is a losing proposition at best of times, add in priority heavy packets like video streaming into the mix and you are just asking for trouble.
Also, removing wifi from the mix will remove one more layer. Bottom line, wired eats wifi for breakfast. You only go wifi if you cannot do wired.
AnonymouseUser
9,943
107
When you get the new router, you plug it into one of the available LAN ports on the modem (LAN to WAN, cable should be included), set the modem into Bridge Mode (disables onboard router), and put the new router into AP Mode (default, usually). Setup wireless on your new router, connect to new network, and start testing.
akmaggot666
125
ok my roommates laptop has also 802.11n, would me going wired fix anything with the connection that he's wireless? I used wifi cuz at home I couldn't pull off a 30m cable across the 3/4 house cuz my father had no brain to add ethernet cable into the wall, but now here I can buy one then, website is called www.links.hr but it's down for some reason
akmaggot666
125
lol so basically both having 802.11n connections and we got mixed on configuration, we're set up for max 11Mbps cuz that 1 option right? that's quiet close to our max, gona try to switch later,
https://www.links.hr/hr/routeri-053524#/pageSize=24&viewMode=grid&orderBy=11&pageNumber=3
is this one https://www.links.hr/hr/adsl-router...-4-port-802-11ac-1-wan-port-bezicni-053524091 overkill or are the "extra" or is https://www.links.hr/hr/wireless-ro...1-port-lan-4-port-2x-antena-bezicni-053524150 one just the same, idk where the extra money goes..
and what's the diff between those 2, one is wireless and one isn't? meaning?
https://www.links.hr/hr/adsl-router...1-port-10-100-wan-2x-antena-bezicni-053524158
https://www.links.hr/hr/adsl-router...icni-multifunkcijski-router-usb-2-0-053524167
AnonymouseUser
9,943
107
No, not quite. It is setup to allow b/g/n connections, but if anyone connects with a b or g adapter, it will slow the entire network to b or g speeds. If only n clients are connected, you should get n speeds. Basically with most basic routers, the connection is only as fast as the slowest client.
That said, just because it's rated @ n 150mbps or 300mbps, it doesn't mean you will get those speeds. Those are theoretical and usually only possible in a test setting. Even then wifi is half-duplex, so you only get max 75mbps each direction with n150, or 150mbps with n300, in ideal situations. This FAQ should help clear things up. With two clients using the wireless network simultaneously, most basic n routers will give 37.5mbps to 75mbps to each client. It's confusing I know, and the speed ratings are nothing like wired connections which are full duplex.
There is no major difference between the two that I can tell, at least not in any meaningful way for your situation. I would recommend the Asus RT-N12 D1 over either of those, to be honest.
akmaggot666
125
do I really need to plug the wireless router to my ISP's one? or can I use the new on instead of the ISP's? and if I do the bridge, so both are connected, does the new one still does the connection quality job at it's fullest so the ISP's chinese modem (which is a wireless router right) doesn't pull it down in quality?
AnonymouseUser
9,943
107
The ISP provided router is a modem and a router combo. You cannot have internet without a modem, so if you wanted to eliminate their hardware completely, you'd need either another modem/router combo (eg, not recommended), or a separate modem and router. With just the modem, you can connect a total of 1 (one) devices to the internet. For two or more connections (you and roommate) you'd need a router. The ISP device will likely perform adequate as a dedicated modem (router disabled), so I recommend just adding a new router.
Reactions: VirtualLarry
