Any tips for running with a stroller?
lol I wrote stroller con google images and the one to be attached to the bike appeared.
That one is dangerous, the normal ones aren't.
The one in the image from caveman is fine, those are way better than the other strollers but they cost shittons of money.
If the tolerances are too high (and the price low) it's very possible that it doesn't work well.
Buy a harness and attach yourself to the stroller with a short rope/bar and pull the stroller instead of pushing... -> no problem with pulling to the left and both arms are free.
But be carefull when you have to stop ^_^
Or simply buy a riksha :awe:
The left-pulling thing may not be due to alignment problems on the bracket. It could be that the bearing on the left wheel is does not run as smoothly as the right. Check that both wheels spin freely.
Thanks for the advice. I hadn't thought about that. I'll have to check it out this weekend.
