Originally posted by: vi_edit
How many ports?
Aren't most hubs nowadays as small as the Ethernet ports will permit? 😕 I don't remember seeing a lot of 5 port hubs that are in 3 foot wide housings.Originally posted by: aphex
How many ports?
I need 3 i think...
Wall -> Hub/Switch --> Vonage & Laptop
Originally posted by: spidey07
3-com used to make min switches that were 1 gang plate large. about 4 ports, that fit into a single gang outlet.
Originally posted by: yoda291
isn't there a voip client you can just run on the laptop?
Originally posted by: Crucial
http://www.newegg.com/app/ViewProductDesc.asp?description=17-201-201&depa=0
Gigafast 5 port swith for $5AR. It's a little bigger than a deck of cards not including the power brick.
Originally posted by: aircooled
your vonage box should be a router w/3 port switch (assuming it's the linksys), if it's not, they will send you one for free.
i have the PAP2 which i bought from a retail store.
They make ones w/ routers but thats not the one i have.
Do you already have a router? if not, I'd just pick up a BEFSR41 (they are small and cheap).
You didnt read the whole thread air, did you? 🙂 😀
glad yours works. mine lasted a week, and it's warranty replacement lasted 4 weeks. gave up after that and replaced it with a linksys 8 port switch (still going strong)Originally posted by: jagec
I have the 8-port version of that that I got FAR. It's a good switch, works well, small, light, and fully auto-sensing.
Originally posted by: chuckywang
What's the difference between a switch and router?
