any ideas why my car won't start after being unused for about two weeks?
skim milk
5,784
My car was working fine before I left, now I come back and the car won't start.
Do I just need to jump start the battery? It has been sitting in the outside parking lot for two weeks.
Please help!
Ornery
17
Exactly. Something trickled off the battery. Sometimes that can actually kill it, but not usually. Wouldn't hurt to check the level of the fluid in the cells at this point. Jump it and run it around for 20 minutes, or use a charger on it for a few hours.
Vic
50,422
14,337
"Won't start" is a little too vague if you want someone to diagnose your problem. Let's start simple. Did the starter crank the engine or not?
skim milk
5,784
yea it did
sounds like almost starting but not starting
then after couple more tries by turning the key, the noise started getting weaker
minendo
35,560
22
yea it did
Battery.
Heisenberg
10,621
yea it did
Battery.
Yeah.
Vic
50,422
14,337
yea it did
Battery.
Yeah.
No. Obviously the battery is run down now after cranking but it's not why the car didn't start when the battery was properly cranking the starter.
Heisenberg
10,621
If I had to guess, I'd say the fuel pressure bled off while the car was sitting. When he first tried to start it, there wasn't enough pressure, and by the time there was, the battery was too weak to start it. Course that's just a guess.
Vic
50,422
14,337
Not a bad guess though. Could very well be right. The car was working fine before he left (so he said) so the problem now shouldn't be anything serious.
Jump it and see if some more cranking will help. Don't crank for more than 15 seconds at a time. If it still doesn't start after a few more tries, then something else is the problem, still not the battery.
amdskip
22,530
13
Push and hold the gas to the floor. Do not pump, just once to the floor, hold, crank.
PingSpike
21,761
606
Make sure the flux capacitor is on and that mister fushion has sufficient garbage to create a nuclear reaction.
Vic
50,422
14,337
Originally posted by: bugoox
do you guys really think that stuff is funny?
It's no different than people who think the battery is at fault for an engine not starting just because it was run dead.
You - "It cranked and cranked and wouldn't start."
BAD mechanic - "Sounds like you need to replace the battery." :roll:
skim milk
5,784
so it's not he battery
i called someone over and we tried to jump start the battery... no go.
SilentRavens
666
www.mhughes.info
Could be a number of things, but I would just try and jump start it first.
I don't know if this is a modern - old or whatever car, so there may be a vapor lock in the fuels lines from getting hot while sitting.
If neither of those are it you got me.
Demo24
8,356
9
find a hill, put the car at the top. put it in neutral. let the car get to a decent speed 5 or 10 then put it in drive with the ignition on and see if it will turn over. (works better with a manual)
I think its the gas. Gas breaks down after awhile. try putting something like fuel injector cleaner in or premium to try and get it to a level where it will ignite properly
