GPU computing is a "real application", and in terms of load and power draw, most closely follows furmark, than any game application. I think that using Furmark and Prime95 is in fact very accurate and totally justified, if you want to see a worst-case measurement.
Any card that cannot stand up to furmark is broken, IMHO.
I have been participating in GPGPU computing for
8 years with AXP1600+, P4 2.6 C @ 3.0ghz, E6400 @ 3.4ghz, Q6600 @ 3.4ghz, Core i7 860 @ 3.9ghz, many laptops over the years, Radeon 4890, etc. in SETI@Home, Milkyway@Home. I can guarantee
100% that GPGPU applications are nowhere near the results you will get with Furmark. I know because I test maximum CPU/GPU temperatures with every new platform I have ever bought. Furmark loads
every component in the videocard, which no real world application can do. On the other hand, just because your CPU is Prime95 stable, doesn't mean it's 100% stable in all applications either. Prime95 is not as intense as OCCT or LinX either though.
I have ran Radeon 4890 24/7 in Milkyway@home for 6 months straight. Max temp 82*C vs. 90*C with Furmark at the same fan speed.
that in itself is a valid reason for max stress testing, I think.
Yes. The discussion is about
power not overclocking limits, and Furmark relates to using a real world applications to estimate power usage -- Furmark is great for quickly finding overclocking limits, but for GPU power consumption measurements it is worthless. Even AMD has stated that Furmark is a power virus that has no real world implications for power consumption. The manufacturer which made videocards for nearly 20 years....
Furmark and Crysis stress GPUs similarly.
Not even close!! Furmark puts
more load on the card than any game ever would. If you want to use Furmark for overclock stress testing, go ahead, because it will help you find your overclock limits quicker. However the discussion we have here is about POWER
not overclocking.
Would you test Bugatti Veyron's tires at 290 mph? No you wouldn't because the car can never drive that fast. Furmark's purpose is not to test components for real world usage, but to test
beyond real world usage, hence worst case
theoretical scenario.
It is dangerous. It is like a virus that overdraws the circuit and it *can* damage your PSU, MB and/or video card.
What nonsense. Furmark is a broken torture test that shows absolutely nothing related to real world usage. i am not using it in my testing any longer.
Respect. :thumbsup: It can still be a great tool for quickly finding overclocking artifacts, but not for power consumption measurements.
